Check the overview thread for more information about the meeting.
Present
- Hans Goudey
- Howard Trickey
- Iliya Katushenock
Since the Last Meeting
- Performance
- Nodes
- Geometry Nodes
- Experimental volume nodes
Meeting Topics
- Howard joined to talk about splitting up the boolean V2 work into smaller pieces that could land separately.
- The first commit would be adding a solver option to the boolean node, adding the ability to use the float “non-exact” solver there.
- Then the exact arithmetic library for large integers, then the boolean algorithm would start to land.
- The current state of the branch outputs loose faces that aren’t connected to each other. This seems like a natural way to split up the review.
- There could be a node info overlay to suggest the experimental feature shouldn’t be depended on.
