The meeting will be on 2024-02-08T17:00:00Z. It is open for everybody interested to join the video call (link below).
Present: Brad Clark, Christoph Lendenfeld, David W (Studio Galt Mocap), Demeter Dzadik, Eduardo Rubio, Felipe G, Nate Rupsis, Nathan Vegdahl, Nika Kutsniashvili, Sybren Stüvel
Links
- Video Call. Note that there are no recordings of the meeting. This way everybody is free to say or show anything.
- A&R Module Meetings calendar for inclusion in your own calendar
- Previous meeting notes
- Issues & Pull Requests
- Draft agenda for any upcoming meetings
- Working title for the new layered animation system: Baklava. Because it consists of layers. And is delicious.
- Blender 4.1 moved to BCon3,
main
branch is now 4.2-alpha. - Meeting agenda restructure:
- No more “Short Term Goals”. These were introduced because the module was in ‘maintenance mode’. Now that we’re working on Baklava, that has changed.
- “Patch Review & Decision Time”: rebranded to “Patches: Review & Decision time”, as decisions about ongoing work are a natural part of the “Ongoing Work” section.
- Animation Baking in ‘maintenance mode’ is now officially documented.
Landed
Names are from the Git log. This list is limited to functional improvements & bugfixes.
Blender
- 660867fa00e: Anim: bone collections, store expanded/collapsed state in DNA (Sybren A. Stüvel) (2024-02-02)
- 79f84775f26: Anim: Motion Paths in camera space (Christoph Lendenfeld) (2024-02-06)
- 446b92d2cec: Anim: Graph Editor - automatically lock key translation to a single axis (Christoph Lendenfeld) (2024-02-06)
- 587b977ec76: Fix #117972: Anim, Bake Action errors when both Pose and Object are off (Sybren A. Stüvel) (2024-02-08)
Add-ons
- 0585a98f: Rigify: use the new boolean and enum custom properties where appropriate. (Alexander Gavrilov) (2024-02-04)
- 220e3500: Rigify: change the pole toggle UI to use On/Off text instead of icons. (Alexander Gavrilov) (2024-02-05)
Technical Documentation
- ce6524f: Update docs/release_notes/4.1/add_ons.md (Alexander Gavrilov) (2024-02-05)
- c1c738f: Animation: new Animation System section (Sybren A. Stüvel) (2024-02-05)
- 0147c7e: Animation: add note about manually reordering FCurve groups (Sybren A. Stüvel) (2024-02-05)
Ongoing Work
- High Prio bugs:
- #117988: Crash when baking action (fix under review)
- Christoph:
- Nathan:
- Nathan’s weekly report
- Finished the ‘basic flow’ mockups and an accompanying write-up: #118008: Initial UX design for the new Animation data model
- Had several meetings about the mockups with various people. Great discussion and feedback from all of them.
- Currently writing up notes from the mockup review meetings, to be posted publicly.
- Sybren:
- Sybren’s weekly report
- Sent an email to the hosting party of the Jitsi instance we’ve been using, to talk about possible solutions to the video streams dropping out.
- Started technical docs on Baklava.
- Baklava: how to deal with F-Curve grouping & ordering?
- Current focus: getting Baklava as experimental feature in
main
as soon as possible, as experimental feature. - Last week’s decision: drop strips for now, store animation data directly on the layers. This will also be reflected directly in the data model (i.e. actually remove strips from it).
- First target: support multiple layers, with only one active layer. All keys go to the active layer, no binding of objects/bones/otherthings to specific layers yet.
- To decide:
- Automatic grouping, manual grouping, or both? For example, Blender could automatically group FCurves by sub-data (i.e. bones, shapekeys). In contrast, this currently only happens very bluntly on F-Curve creation, and so you can actually pop transform FCurves out of their ‘Object Transform’ group and re-group them with bone FCurves.
- Decision: for now limit to what Blender already does. It works for most people, and allows us to move forward quickly.
- Group ordering: should be manual (example: hand bones should be listed in finger order, not alphabetically).
- F-Curve ordering: would this still be necessary if you can group them, name those groups, and reorder them?
- Christoph: important to not allow that. Blender should auto-sort them.
- Nathan: for shapekeys we may want to manually order them, to match the order in the shapekey list.
- Nika: shapekey mode of Dopesheet already does this. Maybe the related code can be used.
- Nika: another example: geometry node outputs, animation for those should also match their order in geonodes.
- Sybren: maybe as a first step we could have an operator to auto-reorder?
- David: auto-sorting would be very nice, as that brings the ability to remove F-Curves and re-add them, where they get back to their original order (instead of Blender’s current newest-last insertion).
- Christoph: an often-heard feature request: FCurve modifiers on groups instead of individual FCurves.
- Animator meeting at Blender HQ:
- Postponed until next Monday, due to production pressure on Project Gold.
Patches: Review & Decision Time
- #115915: Very strange constraint jiggling not present in blender 3.6.3
- TL;DR: this is about an IK/FK switch setup with a single bone chain, where either an IK constraint to the hand is active (for IK), or a Copy Location constraint on the hand (for FK).
- Sybren: Added complexity is that the dependency graph cannot rebuild its relations during animation playback. This means that we cannot just treat an animated disabled/enabled constraint as fully enabled, and later fully disabled.
- Sybren: this setup is seen as a corner case that wasn’t really supported to begin with, and that now “just” results in different behaviour.
- Nathan agrees, as the setup from the bug reporter is meant as an IK/FK switch, so it’s always going to be animated.
- Sybren proposes to lower the priority from ‘high’ to ‘normal’.
- Module agrees.
Next Meeting
The next meeting will be on Tuesday 2024-02-13T11:00:00Z. Again it will be open for everybody who’s interested. The provisionary meeting agenda will be updated before the meeting.
