Is there any chance of the Axes to Rotation node landing in 4.1?
Introducing Quaternions properly into Geometry nodes is fantastic, but in my experience working with Quaternions, creating a Quaternion via two axes in this way is the most common operation, and I think it’s really important to have this node.
Thank you for the reply, I hope we can get that node in 4.2!
Although 4.1 is feature locked, there seem to be lots of inconsistencies with rotation sockets, that I hope can be improved before release:
We have Quaternions now, but the term “Rotation” is being used to refer to Eulers and Quaternions interchangeably which doesn’t make sense.
It looks like most of the nodes have been updated to officially refer to the new Quaternion type as “Quaternion” which I think is good, but the following nodes still call it a “Rotation” socket type:
Simulation input / output
Repeat Zone input / output
Mix
Switch
Group Input
Group Output
The following nodes use the new pink Quaternion socket, but the default value inputs and outputs are Eulers each with XYZ inputs in degrees:
Rotate Vector
Rotate Rotation
Rotation to Axis Angle
Rotation to Euler
Rotation to Quaternion
Other feedback:
Align Euler to Vector - the input and output sockets are called “Rotation” but they are both still using the Vector type. Should these sockets be renamed to “Euler” instead of “Rotation”? (Euler to Rotation node already uses this convention).
I feel like “Rotation to Quaternion”, should be called Separate Quaternion or Spearate WXYZ
and “Quaternion to Rotation” should be called Combine Quaternion or Combine WXYZ
I think we need a Constant Quaternion node to match the other constants
It would be nice to get a Quaternion option in the Random Value node
Vector Rotate node should have a quaternion mode.
Also, question: does the Mix nodes blend via Linear Interpolation or Spherical Linear Interpolation (Lerp vs Slerp)?
“Rotation” is the name of the socket type. It’s designed so that you don’t have to know how rotations are stored internally. And in the future it might even depend on which formats are fastest for each computation.
The rotation sockets still have XYZ Euler controls on input sockets because that’s usually the most intuitive way to control the values by hand, and we had to choose something.
The attribute type is “Quaternion” because for attributes it’s important to be specific about the actual type used for storage.
“Align Euler to Vector” indeed doesn’t have an equivalent yet.
