Check the overview thread for more information about the meeting.
Present
- Dalai Felinto
- Hans Goudey
- Jacques Lucke
Since the Last Meeting
- New Sort Elements node (commit)
- Expose bake id in Python API (commit)
- Expose
bake.node
property in Python API (commit) - Support synchronous baking (commit)
- Reorganize panels (commit)
Meeting Topics
- For the “Manage” panel name in the modifier, it would be good to double check with the UI team in case they have any other ideas for the wording.
- Bake materials
- The initial PR is finished, it needs a bit of testing at this point.
- When there are two maps that conflict with each other, the material alternates every frame.
- Geometry Nodes: Add Rotate Rotation node
- Geometry Nodes: Matrix socket type, attribute type, and initial nodes
- Hans’ proposal is to add these nodes and socket color
- The socket color could go a little bit darker
- Menu Switch node socket color
- Dark gray but without blending with the background.
- Suggestion:
0.4, 0.4, 0.4, 1.0
- Volume nodes
- The old volume nodes were experimental, and were now removed.
- There is already an approved design to the new nodes (using grid sockets).
- There is no official timeline for the grid-version of the volume nodes to be implemented.
- The community is encouraged to contribute them (if they miss the functionality of the old experimental nodes sooner).
- GSoC - Ideas List
