The meeting was on 2025-01-09T17:00:00Z. It is open for everybody interested to join the video call (link below).
Present: Andrew “Andy” Beers, Andrew “Drew” Medina, Brad Clark, Christoph Lendenfeld, David Woolf, Dorothee Dittrich Jonas Holzman, Nacho de Andrés, Nathan Vegdahl, Sybren Stüvel
Links
- Video Call; this is the same URL for every meeting.
- A&R Module Meetings calendar for inclusion in your own calendar app
- Previous meeting notes
- Long Term Plans & Current Focus
- Issues & Pull Requests
- #module-animation chat channel
- Draft agenda for any upcoming meetings
Opening
- Please raise your hand when you don’t understand things for any reason. The purpose of these meetings is collaboration. It is absolutely fine to ask for explanations.
- There are no recordings of the meeting. This way everybody is free to say or show anything they want.
- Happy New Year!
- New blog post: Layered Animation Workshop 2024
- New links in each meeting note (in the list at the top): Long Term Plans & Current Focus (thanks Habib Gahbiche for the suggestion).
New Faces
- Andy: wants to help with C++. Has 10y experience in webdev, last 2y in the OpenUSD group as contributor. Wants to get job in this field, so wants to understand more & hang out with as many modules as possible to get a sense of what to focus on.
- Jonas: Volunteer Blender Developer & Blender’s macOS Platform Maintainer. Software Developer at Autour de Minuit / ADV Studios.
Landed
Names are from the Git log. This list is limited to functional improvements & bugfixes.
Blender
- 426d1683eec: Import: explicitly create & assign action slots when importing BVH/FBX (Sybren A. Stüvel)
- 2d1fc1bcddb: Fix #132195: Unable to key mesh attributes (Christoph Lendenfeld)
- 266d1e8d2fd: Anim: do not draw constraint relationship lines for invalid targets (Sybren A. Stüvel)
- 7636e6fca4c: Fix #132182: Graph Editor slider increment having no visible effect (Christoph Lendenfeld)
- b7d18210e9c: Fix #132193: bone snapping fails under specific conditions (Sybren A. Stüvel)
- c6d6efaaa2f: Fix #132606: ActionSlots can be created with too long names (Sybren A. Stüvel)
- 6b421326b60: Fix #131495: Pose Library error with enum values (Christoph Lendenfeld)
- 63adbb19fb8: Anim: Always name the slot “Legacy Slot” when versioning legacy Actions (Sybren A. Stüvel)
- 2f84d20455d: Anim: Fix versioning of pre-2.50 animation data (Nathan Vegdahl)
- 446f0a806ed: Anim: version Actions before versioning Action Assignments (Sybren A. Stüvel)
- ed58b945dd6: Anim: fix versioning of empty legacy Actions (Sybren A. Stüvel)
Technical Documentation
- 39a035cc: 4.4: Anim, constraint relationship lines (Sybren A. Stüvel)
Ongoing Work
- High Prio bugs:
#131987: 4.3 NLA Editor Causes Consistent Crash to Desktop with Stashed Shader Keyframes(fixed)#130136: “Purge Unused Data” causing a crash when saving file(fixed)Two importer issues: #131305: BVH & #132110: FBX(fix)#132195: Cannot insert keyframe on attribute from Python(fix)#131839: Dope sheet crash(fix)
- Christoph:
- Christoph’s weekly report
- bugfixes
- working on slotted poses #131840: Pose Library Polish implementation (#132601 and #132747)
- prototype with build: #130987 - WIP: pose library updates prototype - blender - Blender Projects
- Working on thumbnail capturing for assets directly from Blender with click-dragging an area of Blender.
- Christoph: Should the pose library be in Python or C++?
- Sybren: explains why currently it’s in Python. Basically it’s so that studios who want to create pose assets in a different way can turn off the add-on and create their own. The basic building blocks are already implemented in C++.
- Sybren: The plan is to move to a system of “hooks” that add-ons can use to customise the behaviour of the pose library, instead of having to replace the entire add-on. That will also make it possible to move Blender’s pose library code out of the ‘core add-ons’ and into Blender itself.
- Christoph: UI will stay in Python anyway, giving people control there as well.
- Nathan:
- Nathan’s weekly report
- Working on improving/writing code/developer docs for slotted and layered actions:
- Once those are landed, I’ll move on to cleaning up the Dope Sheet/Action editor header, and other winter-of-quality tasks.
- Sybren:
- Sybren’s weekly report
- Published blog post Layered Animation Workshop 2024 (written by Nathan and me)
- Landed big PR stack relating to versioning of legacy-to-slotted Actions:
- Finished but decided not to land #131426: Anim: handle library overrides when versioning legacy Actions
- Animator meeting at Blender HQ, with Rik Schutte:
- Just a quick demo by Rik of his animation test using slotted Actions.
- His experience: it works really well
Patches: Review & Decision Time
Jonas: #131810: UI: Transparent Armature Bone Selection
- This PR makes the bones wireframe, removes the transparent faces. This makes them selectable by their wire (because of OpenGL selection).
- How to display this in the viewport? As a separate option? Or as the default behaviour when the Armature is in Display: Wireframe mode?
- Nathan: the current way in “wireframe” mode is functionally useless. Jonas & Brad agree. Let’s get rid of that entirely.
- Nathan: the proposed approach is inconsistent with the way meshes are drawn. Not even sure if we should care about this. In mesh edit mode, wireframe has semi-transparent faces; in object mode meshes are drawn as true wireframe.
- Sybren: seeing the (lack of) faces is important in mesh edit mode. For armatures, you’re not editing faces anyway.
- Jonas: there are so many “wireframe” modes that they get confusing, so might be better to remove shading options rather than adding one more.
- Sybren: likes the look of the semi-transparent faces, but understands that this impacts selection as well. Nathan thinks they’re pretty too.
- Sybren: can we draw the semi-transparent faces, but skip them for selection? Jonas: not now, would be a big refactor.
- Related: #131032: UI: Viewport X-Ray modes disambiguation
- Jonas: We need a proper design for the whole X-Ray shading in Blender. Armature “X-Ray” mode is not even true X-Ray (in the sense of seeing through things), but is just “draw in front”.
- Jonas has a wish for the alt-click menu to highlight bones when you hover over the bone name list. Nacho: people also have the opposite wish, where you can see the name of what you are about to select.
- Nathan: a version of alt-select that doesn’t show the menu would be nice too, so that the menu itself doesn’t cover the bones you want to select from. Maybe more like a slider that highlights the bones one by one would be good? Thumbs up from Christoph.
- Sybren: even with my limited rigging experience, I’ve cursed at how hard it is to select overlapping bones. Thank you for making this PR.
- Jonas will also discuss his PR with the UI module. His plan is to hopefully get the PR landed in the current state, before moving to a full blown redesign of the selection / shading approach.
Sharing Interesting Stuff
Brad shares #132406: WIP: FBX import via ufbx
- Might need Animation & Rigging module eyes on it, to help with animation import/export into slotted Actions.
Sybren shares the work Julien Duroure did for supprting slotted Actions in glTF: #132771: glTF: Manage slotted Actions
Brad: Mindbender Studio are working on a bigger game project with Blender. Brad is helping them out.
Brad: Duncan Rudd is sharing more procedural rigging/modeling stuff via geometry nodes: YouTube.
Drew: he and some friends are doing daily Blender challenges via his YouTube Channel’s Shorts.
Next Meeting
The next meeting will be on Tuesday 2025-01-14T11:00:00Z. Again it will be open for everybody who’s interested. The provisionary meeting agenda will be updated before the meeting.
