User Interface Module Meeting
Regular User Interface module meeting for planning and coordination. Next meeting on December 5.
Attendees
- Julian Eisel
- Hans Goudey
- Thomas Dinges
- Harley Acheson
Merged to 4.0 Since Last Meeting
- Fix #113287: Industry Compatible Keymap: Node Editor Search missing #113446
- UI: Highlight Selected Item in View3D Mode Menu #112058
- Revert: Hide Mouse in Redo Panel Inputs #113551
- UI: Type To Search And Space Bar Search #113520
- UI: Window Title Blender Path Changes #113560
- Fix #113511: Win32 Warping Needs Screen Edge Margin #113565
- Fix #113689: Improved BLF_width_to_strlen Measurement #113698
- Fix #113682: Improved Text Caret Position #113707
- Fix #113885: Drag and Drop colors misses an undo push #113887
- Fix #113826: Set Explicit Font Size for Overlays #113868
- Fix #66286: DblClick to rename UIList items within a popover not working #114363
Merged to 4.1 Since Last Meeting
- UI: Input Placeholders #112104
- UI: Allow Tooltip Padding In Any Order #112487
- Fix #101058: Allow Cryptomatte Picking Between Windows #113636
- UI: Use single column layout on Tangent node #113902
- UI: Modifier Property Icons #113793
- UI: Configurable UI Font Weight #112454
- BLF: Improved Cached Fallback Font Setup #114018
- UI: Improve Mesh Edge Highlighting #111431
- Fix #114080: Add Khmer Font #114719
- UI: Icons for Horizontal and Vertical Split #114433
- Fix #72093: Collapse Wide Enum Lists to One Column #105386
- Fix #102714: Interface Font Selection #113259
- UI: File Browser Display Narrowing #112464
- Outliner: clarify “Show Hierarchy” context menu entry #114139
- Outliner: add “Expand/Collapse All” to view context menu #114138
- UI: Color Picker Position Indication #113753
BCON23 Post Mortem
- Anything we would change?
- UI Module Today Seminar
Snapping Icons
- We’ve decided to keep them as is for now
Near-Term Targets
- UI: Improve menu dropshadow #111794
- Fix #95709: Improve pulldown menu corner rounding #111554
- UI: More Defaults for Search Placeholders #113792
- VFont: Use BLF for font & glyph loading #110187
- UI: Dynamic File Browser Tooltips #104547
- Approved but need quick review by Julian & Pablo
Mid-Term Targets
- UI: Improved Operator Confirmations #104670
- UI: Cleanup Dialog to Manage Orphaned Data #106653
- Core: Allow Optional Use of Harfbuzz and FriBiDi #114947
- Could possibly allow complex shaping (like Arabic) for text objects with some limitations.
Long-Term Targets
- WIP: UI: Icons at 64x64 and Simplified Process #112261
- Simplified by no longer allowing customization. UI range increased. This has interest from the Module, but more investigation will be needed. This might slow down startup as the resizing of the bitmaps are done by the CPU at startup.
- Screen Area Tabs. Mockups? Looks like this would require headers to be always on top. And might also require changes to splitting and merging since the first tab will take action zone space.
- New widgets: Julian mentioned a need for a new slider control. Do we want switches too?
