Practical Info
This is a weekly video chat meeting for planning and discussion of development related to the sculpting and painting in Blender. Any contributor (developer, UI/UX designer, writer, …) working on these features in Blender is welcome to join and add proposed items to the agenda.
Write us a message in the module chat if you’re interested.
- Upcoming Agenda
- Google Meet
- Time: Tuesday 6pm CET
- Next Meeting: November 8, 2022
- Module Chat
Attendees
- Julien Kaspar
- Joe Eagar
- Bastien Montagne
- Daniel Bystedt
Agenda
Since Last Meeting
The Module page has been updated to show both Julien and Joe as coordinators of the module.
Moved
T99615 Sculpt Paint: Smoothing Strength to long term workboard for now. The reasoning is that it’s quite orthogonal to the brush asset project and has in itself bigger implications for the brush engine refactor. See comment on task.
Joe pointed out that we could move towards the sculpt-dev implementation of referring to a mode wide smoothing strength instead of any other brush.
We could also move away from referring to the smooth brush completely for better code.
A more generic unified system is also on the table but would be a way bigger change.
Conclusions need to be reached another time. -
Further discussion on
T101623 Deleting the default cube breaks face set initialization with joining objects. Marked as a Design task from now.
Joe and Hans are working on a cleanup patch. Otherwise the behavior is properly working. -
Added
T101798 Mask from Cavity blurring artefacts.
Joe will try to improve the quality by using cotangent weights. -
Pablo created
D16241 UI: Add Vertex Group and Color Attributes selector in 3D Viewport.
This could be unified with Jeroen’s canvas picker UI.
We also need to consider the current viewport color behavior in sculpt mode for this and what the plan is there. Eventually we don’t want sculpt mode to switch the viewport color setting, but make it more consistent with the other modes. This feature lead to a solution. -
New High Level design task for Brush Asset:
T101895 Brush Asset Project
High Prio Bugs
T101743 Regression: Redo panel created on sculpting
Redo Panel Barrier patch is actually tied to this. Will attach them. -
T101203 Regression: Issues with undoing the visibility of face sets in sculpt mode
Actually already has a patch by Joe. Will move to In Review. -
T100988 Regression: Sculpt Layer brush “strength” jittering while in Drag Dot mode
Poke mentioned devs T96894 Regression: Exported sculpt details are missing till you press clear custom split normals (e.g. after FBX export/import roundtrip)
In Review
D15298 Support Automasking For Texture Paint
Basically accepted. Just one request from Jeroen left. -
D14900 PBVH Texture Paint Node Splitting
Request another review from Jeroen & Brecht?
In Progress
T101593 Auto-Masking Popover for the Header
Main patch landed. There are still missing changes is the Cavity Invert behavior update:
Pie Menu interaction will remain unchanged (Toggle Cavity and Cavity(Inverted)). Instead the pie menu can execute operators to ensure the correct auto-masking settings are toggled.
The auto-masking settings will instead present the cavity toggle as the top level toggle. “Invert” will be a sub-setting to invert the cavity mask. This means cavity and invert will no longer be mutually exclusive toggles.) -
T98070 Improved Rake functionality
Joe is working on it now.
To Do’s
Joe:
- Roll image mapping
- Remaining face set optimizations
Julien:
- Brush Asset UI/UX
- Sculpting & Painting Manual update
Bastien:
- Technical Design of Brush Asset Project
Daniel:
- Occupied with Blender conference
- Further test auto-masking features and maybe demo material
Other Topics
Brush Engine Refactor
We should at some point soon focus on incrementally refactoring the entire brush and sculpting code.
Otherwise it will be hard to add any more features to it and maintain it all.
Brush properties and improved unified settings are things we want to push for, especially for the goal to cherry-pick settings of brush assets.
Could be done separately to the underlying refactor, but not wise to do so.
Sculpt-dev was used for prototyping and working out the design for the intended brush properties and unified settings.
Since these mainly rely on RNA this would be doable to implement.
But we need to review the current implementation and design to see how we can work this into master.
Moving forward we need to define a high level design first and then break down into smaller goals?
(The brush properties being part of that)
High level design = Divide current code into logical blocks and how they need to be used. A global architecture that each tool/brush can access.
How we handle the stroke, tool and resulting data.
Brecht, Jeroen, Bastien and Joe have insights on this but this needs a workshop and scheduled priority.
