The meeting will be open for everybody interested in joining the video call (link below).
Meeting time: 15:00 CEST (Your local time: 2022-06-29T13:00:00Z).
Links
- Jitsi Meet
- Calendar
- Previous meeting notes
- Workboard
- Patches
- #geometry-nodes chat channel
Present
- Andy Goralczyk (Blender)
- Dalai Felinto (Blender)
- Erindale
- Gareth Jensen (Meta)
- Hans Goudey (Blender)
- Iliay Katueshenock
- Jacques Lucke (Blender)
- Natasha (Meta)
- Zhen Dai (NetEase)
General Discussion
- Hair progress update
- We have new tools for hair and selection, aimed at merge today.
- Curve selection (mix/multiply/color/black hair?)
- Currently it blends black into the deselected hair.
- But does that work at all for deselected hair?
- Maybe not a problem, because people don’t tend to do grooming in rendered mode
- More options are helpful, but maybe not necessary.
- The name for the new curves data-block
- “Spline” solved the problem with just the name, but it isn’t correct and doesn’t properly solve the plural problem. A “Curve” containing multiple “Splines” doesn’t make sense.
- “Point” solved this with “Point Cloud”.
- This can be discussed further later. There aren’t any great ideas right now.
- Curves selection outline
- The outline overlay for curves is often disabled, since it can get in the way
- Andy mentioned that it should probably just stay consistent and work for curves objects as well.
- Artist feedback:
- UV of the surface accessible on hair
- The UV itself is already propagated with the add brush or the attachement operators.
- Some attributes could be propagated automatically based on the UVs, but it’s probably best if that’s an explicit choice to keep the tools performing well.
- Procedural interpolation (i.e. children hair) is a big missing item
- Some use cases of the hair system are impossible without it
- UV mode in Attribute Transfer node?
- For propagation of attributes from the surface to curves like colors, etc.
- Hans proposed making it a separate node, mentioning that grouping up so much different functionality in a single node might not make sense
D14864: Curves: Deform curves based on surface node. (WIP)
- This solves another basic use case for the hair system
- It’s still WIP by Jacques. First he wants to get the node working, then worry more about the specific inputs and output sockets
Patch Review & Decision Time
D15306: Add “Use Limit Surface” option to subdivision surface geometry node
- This is a simple patch, basically ready to be committed now
D15274: Geometry Nodes: Shortest Path (WIP)
- The original design was a single node that created a new curve for every path
- The idea was to separate the path calculation from the curve generation
- Avoiding a quadratic algorithm might open many more possibilities
- This could be a field node because it doesn’t modify the mesh
- “At” should be “at”:
Cut at Intersection
, for the Mesh Path to Curve node- The name is a bit confusing in general, it’s not really “cutting”
- “Kill at Intersection” or “Stop at Intersection” or “Merge”
- Geodesic distances are a separate topic
- A vector field on the mesh might be a way to generalize this, but might be harder to implement, or a separate topic
- It might be good to name the node so it doesn’t preclude adding more options in the future
- More feedback could be helpful on the patch. Especially about how to achieve the effect without generating all the redundant data.
D14389: Geometry Nodes: Unwrap and Pack Islands Nodes
- Keep it simple, make it blue
- Geometry nodes are nodes that have geometry inputs and outputs
D10895: T86838 Geometry Nodes: Add Mesh To Volume Node
- An old patch that’s finally ready to be committed.
D15042: Geometry Node: Image Info
- We can ask Brecht about this before committing
- Some screenshots in the description would be helpful
Help Needed
- Nothing was mentioned specifically, but the team is currently focusing on getting Hair available for Blender 3.3.
Next Meeting
The next meeting will be on Wednesday 13 July, 15:00-16 CEST (Your local time: 2022-06-29T13:00:00Z), which is 2 weeks from this meeting. Again it will be open for everyone interested. The provisional meeting agenda will be linked in the #geometry-nodes channel before the meeting.
