Info
Developers or artists interested in contributing are welcome to join at the links below.
- Workboard - plans, ongoing work, and community tasks
- Chat Channel - general development communication
- Video Call - dailies at 14:00 CEST
- Meeting Agendas and Notes - updated throughout the week
Meeting Notes
- Planning for the week
- More foundational work on fields code
- Instances design discussions
- Continuing conversion of more nodes
- Field socket visualization
- Progressing towards merging curve nodes
- T91376: Domain for fields passed to a modifier.
- We choose the domain in the Node Group for now.
- Maybe add an
Auto
option that tries to detect the domain based on the field inputs.- Auto would only work when there are attribute field inputs, and would default to “Point” otherwise.
- T91370: Implicit position field.
- Hans mentioned that sometimes the implicit behavior makes the system harder to understand, though the change still seems worth it.
- What about implicit inputs for different dimensions? We can just use the same behavior as in shading nodes.
- In the future the implicit input system could be generalized so that any node group could use it.
- T90867: Built-in attribute propagation rules
- Not much discussion about this, the idea is straightforward.
- We do what has been proposed in the task.
- Rotate Euler node name
- The Point Rotate node is deprecated because it depended on a generic named attribute implicitly (
rotation
- Reconsidering the “always realize instances” position.
- Jacques will make a devtalk thread
- There was some discussion about whether to make the change for 3.0
- The change is simple in code, is useful for the string to curve node, and it’s better to group design changes in a larger release rather than spreading them out too much.
- Discussion about instancing
- Generally all in agreement that it’s clear that explicit instancing is a better system
- However, longer term, geometry lists may offer a more intuitive solution to some problems, so it’s important to keep that in mind.
- Product Demo
- Default value for Curve Trim should be 0-1, not 0,0 (and similar for length).
- Need task to use attribute search in the Geometry Nodes modifier interface.
- Input attribute toggle should be on the left.
- Organization of inputs in the modifier is currently very awkward. Sub-panels could be configured by adding items to the group outputs list.
- Attribute Remove relevancy?
- Still no consensus about this, but there other design topics to get to, so it will be hidden for now.
