Links
Agenda
- Planning for the week
- Design discussion as needed
Meeting Notes
- Planning for the week (same as last week)
- Continue work on geometry nodes modifier on curve objects
- Socket inspection and related refactors
- More design work on attribute UX improvements
- More curve primitive node discussions (Hans):
Quadrilateral
- Typo: Rectange → Rectangle
- Could have a “Points” mode
Curve evaluation to mesh (Hans)
- We didn’t talk about this at the meeting, but Jacques responded with some feedback earlier
- The consensus is basically slowly transition away from implicit conversion to mesh where possible.
- Quick update on the attributes discussion (Dalai)
- Dalai is working on a new proposal
- Still no consensus among the group
- Geometry Instancing
- Supporting instancing geometry in
GeometrySet
is quite straight forward. So support for it in the Point Instance node is as well.
- Problem: For Blender in general the smallest unit of instancing is the Object.
- Refactoring this to support smaller units of instancing is a major undertaking and also opens up many questions regarding exporting, motion blur, …
- For many things it is not necessary that the geometry is actually instanced, because the instances would be made real anyway.
- Possible approaches that would open up new use cases without forcing us to refactor this core part of Blender now.
- Always realize instances directly in the Point Instance node, if it is not instancing objects are collections.
Point Instance
would be a confusing name.
- Easy to write versioning code once we properly support geometry instances everywhere.
- Automatically realize geometry instances at the end of the modifier stack.
- Might feel like this is hidden from the user, but it’s really not. It could affect exporters, renders, what is shown in the spreadsheet, …
- Add a new node like
Copy to Points
that takes two geometries at copies (without instancing) one geometry to all the points of the other.
- Least confusing option for the user.
- Doesn’t require any “hacking” or versioning.
- Might be faster than using Point Instance plus making instances real when a very small geometry is instanced many times.
- We’ll go with making instances real in the
Point Instance
node for now.
