Links
Agenda
- Planning for the week
- Design discussion as needed
Meeting Notes
- Planning for the week.
- Wrap up viewer node
- Continue work on geometry nodes modifier on curve objects
- Socket inspection and related refactors
- More design work on attribute UX improvements
- Review curve primitive node design. (Hans)
Bezier Segment
- Start/End → Start/End Point
- Another mode where the handles are relative to the start and end points
Quadratic Bezier Segment
- Remove “Segment” from this and the previous
- We were a bit divided on this point, but this name is quite long with that word…
*Circle
- “Start” “Middle” “End” → “Point 1/2/3”
- Default mode should be radius
- It can output the center of the circle as well (for the Points mode)
- Default radius of 1m
- Make sure it “sorts” the inputs so they can work in any order
- If that doesn’t break the rotation order behavior
Arc
- Default can be radius
- Make sure it works for the colinear case
Spiral
- Curve reverse node makes the “reverse” input not necessary
- Resolution can be at the top
Quadrilateral
- Square should be the default
- Different modes would make the options more obvious
- Square: Only a size input
- Rectangle: Width and height inputs
- Parallelogram: Full controls of the current node
- Star
Phyllotaxis Spiral
- “Resolution” should be “Points” to differentiate it from the other spiral
- The different uses-- the “crazy” output for instancing and the smooth “spiral-like” output seem to conflict a bit
- Mostly this isn’t really an actionable point
- But make sure the “smooth” output with a lower angle is also useful
- New
Needs Docs
tag that can be used in conjunction with project tags. (Jacques)
- Allows tagging commits and also tasks.
- Reuse
Documentation
tag?
- Not sure if it has a different meaning already.
- Jacques will make a devtalk thread with a proposal.
- Attribute Smooth Node (Simon)
- A priority for some Sprite Fright work
- Accessing attributes without hardcoded strings (Dalai).
