20 July 2026
20 July 2026
Announcements
Modules & Projects
New Features and Changes
Compositor
  • Default to a Group Input node instead of Render Layers (commit) - (Omar Emara)
Curves
  • New sculpt Cut brush (commit) - (RedMser)
Cycles
  • HIP-RT: Skip visibility check for primitives (commit) - (Sergey Sharybin)
  • HIP-RT: Remove primitive bounds valid check (commit) - (Sergey Sharybin)
  • HIP-RT: Remove BVH steps (commit) - (Sergey Sharybin)
  • HIP-RT: Reduce indirections in the BVH traversal (commit) - (Sergey Sharybin)
  • HIP-RT: Remove custom arrays for primitive indices (commit) - (Sergey Sharybin)
  • HIP-RT: Always use balanced build for BLAS (commit) - (Sergey Sharybin)
  • HIP-RT: Use Balanced for Hair and Quality for triangles (commit) - (Sergey Sharybin)
  • HIP-RT: Use Balanced BVH for pointcloud primitive (commit) - (Sergey Sharybin)
  • Use minimum 64x64 tile size for texture cache load (commit) - (Brecht Van Lommel)
Geometry Nodes
  • Add “Miter Scale” option to curve to mesh node (commit) - (Hans Goudey)
Keymap
  • Nodes: Shift+X for dissolve and Ctrl+X for Cut (commit) - (Habib Gahbiche)
Modeling
  • Warn when spacing edge loops evenly on face selections (commit) - (Tariq-Sulley)
Nodes
  • Convert Grease Pencil node enums to menu sockets (commit) - (quackarooni)
  • Properly name node after link-drag-search (commit) - (Brady Johnston)
Outliner
  • Use active element for creating new collection (commit) - (Pratik Borhade)
Sculpt
  • Add option to transform only pivot (commit) - (ethan)
Texture Paint
  • Remove boolean “tag” from UVBorderEdge struct (commit) - (Hans Goudey)
  • Slightly improve UV island construction (commit) - (Hans Goudey)
  • Store UV border edge primitive index as index (commit) - (Hans Goudey)
  • Simplify access to UV map data (commit) - (Hans Goudey)
  • Reference UVEdge by index (commit) - (Hans Goudey)
  • Reference UVVert by index (commit) - (Hans Goudey)
  • Slightly optimize triangle edges creation (commit) - (Hans Goudey)
Theme
  • Cleanup: Remove Theme Space Title setting (commit) - (Pablo Vazquez)
UI
  • Improved IME Support (commit) - (Campbell Barton)
  • Multi-line labels (commit) - (Guillermo Venegas)
Utilities
  • Add batch files to help launch Blender with OpenGL backend and factory settings (commit) - (Alaska)
VSE
  • Update scene strip content length when scene changes length (commit) - (Falk David)
XR
  • Add Vive Tracker interaction profile extension (commit) - (Ethan Porcaro)
Weekly Reports
