20 December 2021
20 December 2021
Announcements
Modules & Projects
USD
New Features and Changes
Video Sequence Editor
  • Clamp sound strip when adding movie strip (commit) (Richard Antalik)
  • Autokey support for image transforms in preview area (commit) (Philipp Oeser)
User Interface
  • Support Copy To Selected for id-properties [GN modifier properties] (commit) (Philipp Oeser)
  • Various tweaks to spelling and layout (commit, commit, commit) (Phil Stopford, Philipp Oeser, Johannes Jakob)
  • Undo History (in the Edit menu), now expands as a sub-menu instead of being a separate popup. (commit) (Campbell Barton)
Node Editor
  • Add a search menu when dragging links over empty space (commit) (Hans Goudey)
  • Add vector support to Map Range node in geometry and shader nodes (commit) (Charlie Jolly)
Geometry Nodes
  • Support instance attributes when realizing instances (commit) (Jacques Lucke)
  • Significantly improve performance and decrease memory usage when evaluating fields (commit) (Jacques Lucke)
  • Support point clouds in the set material node (commit) (Hans Goudey)
  • Add a Selection input to the Attribute Statistics node (commit) (Johnny Matthews)
Cycles
  • Add rendering support for point cloud data (commit) (Brecht Van Lommel)
  • Enable Apple Metal GPU rendering (commit, commit) (Brecht Van Lommel)
Library Overrides
  • Improve performance of override creation and resync by 3-4x and 1.1x (commit, commit) (Bastien Montagne)
Metaballs
  • Optimize memory usage for meta-ball tessellation (commit) (Campbell Barton)
Grease Pencil
  • Add randomize options to Length modifier (commit) (Cody Winchester)
  • Add a Shrinkwrap modifier (commit) (Antonio Vazquez)
Animation & Rigging
  • New add-on for copy-pasting world-space transform between objects and pose bones (commit) (Sybren Stüvel).
Weekly Reports
