2 March 2026
Modules & Projects
- 2026-02-24 Animation & Rigging module meeting
- 2026-02-24 Nodes & Physics Module Meeting
- 2026-02-24 User Interface Meeting
- 2026-02-17 Texture Paint / Baking Kickoff Meeting
- 2026-02-27 Projects Updates meeting
New Features and Changes
Camera
- Support resizing orthographic cameras via its gizmo (commit) - (Marc Hamamji)
Compositor
- Node Gizmos in the Image Editor (commit) - (Habib Gahbiche)
- Support Display Window in domain realization (commit) - (Omar Emara)
- Allow different extension mode per axis for EWA (commit) - (Omar Emara)
- Add Jacobian matrix argument to sample function (commit) - (Omar Emara)
Cycles
- oneAPI: use ocloc 101.8424 on Windows (commit) - (Nikita Sirgienko)
- Improve Metal state allocation logic for RAM-constrained systems (commit) - (Michael Jones)
- Add Normal Map node Base option for displaced surfaces (commit) - (Brecht Van Lommel)
GPU
- Framebuffer: Use double4 for clear values (commit) - (Clément Foucault)
- Move GPU_THREAD to compat header (commit) - (Clément Foucault)
- Avoid implicit type cast in shader printf implementation (commit) - (Clément Foucault)
- Shader: Support template specialization inside namespaces (commit) - (Clément Foucault)
- C++ Shader Compilation: Use concepts and avoid type_traits (commit) - (Clément Foucault)
- Shader Preprocessor: Optimize and cleanup implementation (commit) - (Clément Foucault)
Geometry Nodes
- Skip creating weights for nearest sample (commit) - (Hans Goudey)
- Add “Set Curve Order” node (commit) - (Romain Guimbal)
- Expose modifier socket visibility to RNA (commit) - (Alex Tkachyov)
- Optimize interface socket identifier lookups to O(1) (commit) - (Alex Tkachyov)
Grease Pencil
- Support viewport compositor depth pass (commit) - (Omar Emara)
Modeling
- To circle operator from looptools (commit) - (Tariq-Sulley)
Node Wrangler
- Do nothing in Align Nodes operator if selection is empty (commit) - (quackarooni)
Nodes
- Add cut to context menu and remove shortcut (commit) - (Habib Gahbiche)
- Add Boolean, Integer, and Vector input nodes in Shader Editor (commit) - (quackarooni)
- Add missing input nodes for constant values (commit) - (Lukas Tönne)
- Preserve input values when ungrouping (commit) - (Lukas Tönne)
Object Mode
- Enable target operator for cameras (commit) - (Eqkoss / T1NT1N)
Remesh
- Interpolate vertex and corner attributes (commit) - (Sean Kim)
Render
- Shader Editor Add Menu cleanup (commit) - (Miguel Pozo)
Sculpt
- Add primitive tool in Sculpt Mode. (commit) - (kunal)
- Restrict a number of properties from grab tools (commit) - (Sean Kim)
UI
- Do Not Use Initial Ctrl for Image Zoom (commit) - (Harley Acheson)
- Handle File Browser Invalid Saved Params (commit) - (Harley Acheson)
- Add target operator to light and camera context menu (commit) - (Eqkoss / T1NT1N)
- Fix title of now collapsible View3D Shading popover Color subpanel (commit) - (Jonas Holzman)
VSE
- GPU support for compositor modifiers/effects (commit) - (Aras Pranckevicius)
- Compositor modifiers/effects can use half precision on GPU now (commit) - (Aras Pranckevicius)
Vulkan
- Reduce small allocations in push constants (commit) - (Jeroen Bakker)
Weekly Reports
- Aaron Carlisle
- Alaska
- Bart van der Braak
- Bastien Montagne
- Campbell Barton
- Casey Bianco-Davis
- Christoph Lendenfeld
- Clément Foucault
- Dalai Felinto
- Falk David
- Guillermo Venegas
- Habib Gahbiche
- Hans Goudey
- Harley Acheson
- Jacques Lucke
- Jeroen Bakker
- Jesse Yurkovich
- John Swenson
- Jonas Holzman
- Julian Eisel
- JulienDuroure
- Lukas Tönne
- Kévin Dietrich
- Mark van de Ruit
- Martijn Versteegh
- Miguel Pozo
- Nathan Vegdahl
- Nika Kutsniashvili
- Omar Emara
- Pablo Vazquez
- Philipp Oeser
- Pratik Borhade
- Richard AntalĂk
- Sean Kim
- Sebastian Herholz
- Sergey Sharybin
- Sybren StĂĽvel
- Tariq Sulley
- Thomas Dinges
- Weizhen Huang
- Wu Yiming
