12 January 2026
12 January 2026
Welcomes
Announcements
Modules & Projects
New Features and Changes
Anim
  • More elaborate info when pasting a pose (commit) - (Sybren A. Stüvel)
Assets
  • Disable editing catalogs in essentials asset library (commit) - (Julian Eisel)
BLI
  • Optimize RLE encoding for random data spans (commit) - (Campbell Barton)
Compositor
  • Support display window in Image node (commit) - (Omar Emara)
  • Propagate images meta-data to File Output (commit) - (Omar Emara)
  • Allow directories in File Output item names (commit) - (Omar Emara)
  • Add Mask To SDF node (commit) - (Omar Emara)
Cycles
  • oneAPI: use ocloc 101.8331 on Windows (commit) - (Nikita Sirgienko)
Geometry Nodes
  • Icons of domains in enums (commit) - (Iliya Katushenock)
Grease Pencil
  • Performance: Multi-thread draw cache extraction (commit) - (Angus Stanton)
Linux
  • replace JEMALLOC with TBB_MALLOC_PROXY (commit) - (Campbell Barton)
Node Editor
  • Reduce padding on View All/Selected (commit) - (Pablo Vazquez)
Nodes
  • Automated tests for group operators (commit) - (Lukas Tönne)
  • Tests for group operators applied to nested frames (commit) - (Lukas Tönne)
  • Add more node group operator tests for external socket links (commit) - (Lukas Tönne)
Object
  • Update poll methods for transform conversion methods (commit) - (Sean Kim)
Polyfill2D
  • Minor optimization to bounds calculation (commit) - (Campbell Barton)
  • Precompute edge vectors for point-in-triangle test (commit) - (Campbell Barton)
  • Collapse single-child nodes on KDTree removal (commit) - (Campbell Barton)
  • Add KDTree index cache for ear triangle intersections (commit) - (Campbell Barton)
Python
  • Add function to run a script with specific local variables (commit) - (Sybren A. Stüvel)
Sculpt
  • UI: Update Stabilize Normal / Stabilize Center parameter tooltip (commit) - (Sean Kim)
  • Add new brush type for color blurring (commit) - (kunal)
UI
  • Grease Pencil: Add Search to Move to Layer menu (commit) - (Pablo Vazquez)
  • Full Outlined Selection Icons (commit) - (Harley Acheson)
  • Improve Color Picker Hex color code auto-completion (commit) - (kh4f)
  • Rename ‘Frame Last Stroke’ to ‘Center Last Stroke’ for paint modes (commit) - (Nick Steiner)
  • Tree View: Copy/Paste name of the viewitem under mouse (commit) - (Pratik Borhade)
  • Add socket icons in Shader AOVs list (commit) - (quackarooni)
  • MacOS SVG Cursors (commit) - (Harley Acheson)
  • Fix incorrect tooltips in Color Picker widget (commit) - (kh4f)
  • Extensions: Add “Update All” convenience button (commit) - (Pablo Vazquez)
  • Resize Aligned Regions (commit) - (Harley Acheson)
  • Improved File Overwrite Feedback (commit) - (Harley Acheson)
USD
  • Handle glass setups for the UsdPreviewSurface (commit) - (Jesse Yurkovich)
VSE
  • Avoid out running out of memory when adding many movie strips (commit) - (Jacques Lucke)
  • Show total proxy build progress when building multiple proxies (commit) - (Jacques Lucke)
macOS
  • Add iCloud Drive support to the File Browser (commit) - (Jonas Holzman)
Weekly Reports
