11 May 2026
Modules & Projects
- 2026-05-05 Nodes & Physics Module Meeting
- 2026-05-05 Animation & Rigging module meeting
- 2026-05-06 User Interface Meeting
- 2026-05-07 Triaging Module Meeting
- 2026-05-08 Project Updates meeting
- 2026-05-11 Viewport & EEVEE module meeting
New Features and Changes
Alembic
- Support importing static object visibilities (commit) - (Kévin Dietrich)
Anim
- Disable applying online pose assets (commit) - (Julian Eisel)
Assets
- Allow filtering out asset catalogs for experimental features (commit) - (Lukas Tönne)
- Disable activating online brush assets (commit) - (Julian Eisel)
- Add Python function to cancel download (commit) - (Sybren A. Stüvel)
Compositor
- Default to 2D for compositor texture nodes (commit) - (Omar Emara)
- Add Film Grain built-in asset (commit) - (Selman Vorhoff)
- Add descriptive tooltips for filter types (commit) - (ashri11b-png)
- Port rotation nodes from geometry nodes (commit) - (Criss-Ivana)
- Use GPU by default (commit) - (Omar Emara)
- Allow anisotropic sampling for transformations (commit) - (Bill Spitzak)
- Add “Open” operator to Keying Screen node (commit) - (quackarooni)
- Optimize extended boundary blurring (commit) - (Omar Emara)
- Support drag and drop objects from the outliner (commit) - (Habib Gahbiche)
- Expose Rotation output in Object Info node (commit) - (Criss-Ivana)
Cycles
- Use square root in denoising roughness before weighted sum (commit) - (Christoph Neuhauser)
- Add denoising backward motion vector pass with depth delta (commit) - (Christoph Neuhauser)
- Hydra: Add basic add-on to render inside Blender (commit) - (Brecht Van Lommel)
EEVEE
- Remove unused shadow tile copy technique (commit) - (Clément Foucault)
- Port remaining Virtual shadow map managment shaders to BSL (commit) - (Clément Foucault)
- Add ray backface hit behavior option (commit) - (Clément Foucault)
- Revert backface heuristic change (commit) - (Clément Foucault)
- Better screen space thickness heuristic (commit) - (Clément Foucault)
- Use visibility bitmask for AO node (commit) - (Clément Foucault)
- Reduce the number of UniformBuf uploads (commit) - (Miguel Pozo)
Geometry Nodes
- Support data-blocks in compare node (commit) - (Jacques Lucke)
- Improve debug print for repeat zone compute context (commit) - (Jacques Lucke)
- Draw data-block names in viewer node (commit) - (Jacques Lucke)
- Add Merge by Distance building block nodes (commit) - (_илья __)
Grease Pencil
- Add playback benchmark tests (commit) - (Falk David)
Mesh
- Improve dissolve degenerate with no geometry found message (commit) - (Tariq-Sulley)
Modifiers
- Keep active state in “Copy Modifiers to Selected Objects” (commit) - (Philipp Oeser)
Nodes
- Dynamic declaration for dynamically-typed function nodes (commit) - (_илья __)
Outliner
- Enable scroll to active by default (commit) - (Pratik Borhade)
Paint
- Hide ‘Modes’ panel (commit) - (Sean Kim)
Rigidbody
- Sync GImpact mesh with collision margin (commit) - (valadaptive)
UI
- Add missing translation context to textbox placeholder text (commit) - (Guillermo Venegas)
- Add missing space in Light Probe tooltip (commit) - (MarcHamamji)
- Make EEVEE denoise option more compact (commit) - (Clément Foucault)
- Gray-out Sound Preferences when Audaspace is disabled, use column layout (commit) - (Jonas Holzman)
- Anim: Sort Mirror key menu (commit) - (Pablo Vazquez)
- Anim: Sort Mirror key menu in Dope Sheet (commit) - (Pablo Vazquez)
- Assigning shortcut to individual enum item from context menu (commit) - (Pratik Borhade)
- Launch OS file browser when clicking on uneditable path properties (commit) - (Nathan Vegdahl)
USD
- Implement incremental save for export (commit) - (Jesse Yurkovich)
Vulkan
- Add CLI GPU selection (commit) - (Le Gia Bao)
Weekly Reports
- Aaron Carlisle
- Alaska
- Bart van der Braak
- Bastien Montagne
- Campbell Barton
- Casey Bianco-Davis
- Christoph Lendenfeld
- Clément Foucault
- Dalai Felinto
- Falk David
- Guillermo Venegas
- Habib Gahbiche
- Hans Goudey
- Harley Acheson
- Jacques Lucke
- Jeroen Bakker
- Jesse Yurkovich
- John Swenson
- Jonas Holzman
- Julian Eisel
- JulienDuroure
- Lukas Tönne
- Kévin Dietrich
- Mark van de Ruit
- Martijn Versteegh
- Miguel Pozo
- Nathan Vegdahl
- Nika Kutsniashvili
- Omar Emara
- Pablo Vazquez
- Philipp Oeser
- Pratik Borhade
- Richard Antalík
- Sean Kim
- Sebastian Herholz
- Sergey Sharybin
- Sybren Stüvel
- Tariq Sulley
- Thomas Dinges
- Weizhen Huang
- Wu Yiming
