1 June 2026
Modules & Projects
- 2026-05-26 Sequencer Meeting
- 2026-05-26 Sculpt, Paint & Texture Module Meeting
- 2026-05-28 User Interface Meeting
- 2026-05-28 Animation & Rigging module meeting
- 2026-05-29 Remote Asset Libraries: Go or No-Go for 5.2?
- 2026-06-01 Viewport & EEVEE module meeting
New Features and Changes
Anim
- Remove âCurrent Frameâ update mode of motion paths (commit) - (Christoph Lendenfeld)
- Allow select key by type in Graph Editor (commit) - (Christoph Lendenfeld)
- Update âuse_deformâ property name and label (commit) - (Wayne Dixon)
- Set b-bone default scale in/out to 1.0 (commit) - (Wayne Dixon)
Assets
- Show whether downloaded online asset files match the remote (commit) - (Sybren A. StĂŒvel)
- Shift+Click refresh button to refresh remote asset listing (commit) - (Sybren A. StĂŒvel)
- Add âOpen File Locationâ to asset browser context menu (commit) - (Sybren A. StĂŒvel)
- Disable âOpen Blend Fileâ for online assets and essentials (commit) - (Julian Eisel)
Compositor
- Shorten socket tooltip for extension mode (commit) - (Omar Emara)
Core
- LibOverride: Refactor libs deps depth issues reporting. (commit) - (Bastien Montagne)
- Add icon for indirect packed data-blocks (commit) - (Jacques Lucke)
- Add basic Tracy integration (commit) - (Sean Kim)
Cycles
- Tune inlining to fix oneAPI performance regression (commit) - (Xavier Hallade)
- Texture cache generate support for image sequences (commit) - (Brecht Van Lommel)
- Texture cache clear operator (commit) - (Brecht Van Lommel)
- Hydra: Change render delegate to use Hydra 2.0 API (commit) - (Brecht Van Lommel)
- Rework the workaround for #158123 to improve stability (commit) - (Nikita Sirgienko)
GPU
- Reduce stack usage in ShaderCreateInfo::finalize (commit) - (CleÌment Foucault)
- Split gpu_shader_create_info_init into different functions (commit) - (CleÌment Foucault)
- Force use of GLSL precise derivatives (commit) - (Clément Foucault)
- Shader Tool: Prevent local reference shadowing (commit) - (CleÌment Foucault)
Geometry Nodes
- Remove anonymous attributes after evaluation (commit) - (Jacques Lucke)
- Iterate on force evaluation and Custom Force asset (commit) - (Jacques Lucke)
- Remove local filter and expose error threshold in dynamics groups (commit) - (Jacques Lucke)
- Improve support for custom effectors in dynamics groups (commit) - (Jacques Lucke)
- Support empty exclusion list in Transfer Attributes node (commit) - (David Murmann)
- Add Self Object as default input mode for object sockets (commit) - (Jacques Lucke)
- Move geometry bundles out of experimental (commit) - (Jacques Lucke)
- Move Transfer Attributes node out of experimental (commit) - (Jacques Lucke)
- Add Principal Component Analysis node-group assets (commit) - (Simon Thommes)
- Add test for PCA nodes (commit) - (Simon Thommes)
- Add experimental hint to xpbd solver node label (commit) - (Jacques Lucke)
- Closure to List node (commit) - (Hans Goudey)
Grease Pencil
- New Fill Tool Algorithm (commit) - (Casey Bianco-Davis)
- Support setting âScene Unitâ importing SVGs (commit) - (dupoxy)
Keymap
- Frame active element with Mouse Button 4 (commit) - (1P2D)
Metal
- Improve generated code error line (commit) - (CleÌment Foucault)
Nodes
- Show single line by default in new String input nodes (commit) - (Jacques Lucke)
- Add â3D to Screen Spaceâ and âScreen Space to 3Dâ node assets (commit) - (Habib Gahbiche)
- Move linked node groups to submenu in add/swap menu (commit) - (Jacques Lucke)
- New Set String Case node (commit) - (Brady Johnston)
Object
- Add Geometry Nodes support for Empty object type (commit) - (Falk David)
- Collection Instance: Use geometry in modifier evaluation (commit) - (Falk David)
Render
- Hydra: Migrate render delegate to use Hydra 2.0 API (commit) - (Brecht Van Lommel)
Shaders
- Gray out unused thin wall subsurface input in Principled BSDF (commit) - (Brecht Van Lommel)
UI
- Image: Use title case in Open Images operator (commit) - (Pablo Vazquez)
- Show UV grid overlay options in all Image Editor modes (commit) - (Jonathan Lampel)
- Shorten FCurve modifier warning text (commit) - (Pratik Borhade)
- Theme: Organize panels (commit) - (Pablo Vazquez)
- Grid view region scrolling when active element is changed (commit) - (Pratik Borhade)
- Add âLink to Sceneâ operator in Outliner context menu for objects (commit) - (1P2D)
- Refresh grayed out state of active buttons on redraw (commit) - (Julian Eisel)
- Add new Download icon and use it for assets (commit) - (Pablo Vazquez)
- Center panel category tab icons (commit) - (Guillermo Venegas)
- Add unit hint when text editing number values (commit) - (Falk David)
- Add icon for completed downloads (commit) - (Pablo Vazquez)
- Reorganize âTransformâ menu (commit) - (Nika Kutsniashvili)
- Focus active element with period key in views (commit) - (Pratik Borhade)
UV
- Original bounding box unwrapping (commit) - (Eitan Traurig)
VSE
- Detect when compositor effect/modifier is fully opaque (commit) - (Aras Pranckevicius)
- Add absolute line spacing to text strips (commit) - (AleĆĄ JelovÄan)
- Add profiler markers (commit) - (Aras Pranckevicius)
- Implement composition guides overlay in preview (commit) - (golden-dragon)
- Add
streamparameter to sound/movie import API (commit) - (John Kiril Swenson)
Vulkan
- Improve Color-space logging (commit) - (Jeroen Bakker)
- Add debug name to VMA allocations and print leaks to stderr (commit) - (Miguel Pozo)
glTF
- Enable EXT_meshopt_compression & KHR_meshopt_compression (commit) - (Julien Duroure)
Weekly Reports
- Aaron Carlisle
- Alaska
- Bart van der Braak
- Bastien Montagne
- Campbell Barton
- Casey Bianco-Davis
- Christoph Lendenfeld
- Clément Foucault
- Dalai Felinto
- Falk David
- Guillermo Venegas
- Habib Gahbiche
- Hans Goudey
- Jacques Lucke
- Jeroen Bakker
- Jesse Yurkovich
- John Swenson
- Jonas Holzman
- Julian Eisel
- JulienDuroure
- Lukas Tönne
- Kévin Dietrich
- Mark van de Ruit
- Martijn Versteegh
- Miguel Pozo
- Nathan Vegdahl
- Nika Kutsniashvili
- Omar Emara
- Pablo Vazquez
- Philipp Oeser
- Pratik Borhade
- Richard AntalĂk
- Sean Kim
- Sebastian Herholz
- Sergey Sharybin
- Sybren StĂŒvel
- Tariq Sulley
- Thomas Dinges
- Weizhen Huang
- Wu Yiming
