Hey all, I’ve recently been working on a MoonRay plugin for Blender. You can see the code that I have at the moment.
I’m a bit stuck on linking the hdMoonrayRendererPlugin to a bpy.types.HydraRenderEngine in Blender 4.1.
I’ve successfully built MoonRay for RHEL9, but when trying to register the plugin, I first get:
Import failed for module 'pxr.UsdMtlx'! ModuleNotFoundError: No module named 'pxr.UsdMtlx'
It also says that Plugin HdMoonrayRendererPlugin is missing TfType registration
It’s hard to say much without the complete error message, and an explanation of what you were doing (like running a particular command). Otherwise there is too much guesswork.
Note that running import pxr.UsdMtlx
in the console editor in Blender works for me.
One thing to be aware of is that you should build Hydra plugins against the same USD version that Blender uses.
It seems the website doesn’t like me copy and pasting the full error message, but here’s a screenshot of the full warning.
import bpy
class MoonRayRenderEngine(bpy.types.HydraRenderEngine):
bl_idname = "MOONRAY"
bl_label = "MoonRay"
bl_info = "Dreamworks' MoonRay Production Renderer integration"
bl_use_preview = True
bl_use_gpu_context = True
bl_use_materialx =False
bl_delegate_id = "HdMoonrayRendererPlugin"
@classmethod
def register(cls):
import pxr.Plug
pxr.Plug.Registry().RegisterPlugins(['/home/cjhosken/org/dreamworks/openmoonray/plugin'])
def get_render_settings(self, engine_type):
settings = bpy.context.scene.moonray
result = {}
if engine_type != "VIEWPORT":
result |= {
'aovToken:Combined': "color",
'aovToken:Depth': "depth",
return result
def update_render_passes(self, scene, render_layer):
if render_layer.use_pass_z:
self.register_pass(scene, render_layer, 'Depth', 1, 'Z', 'VALUE')
def update(self, data, depsgraph):
super().update(data, depsgraph)
def register():
bpy.utils.register_class(MoonRayRenderEngine)
def unregister():
bpy.utils.unregister_class(MoonRayRenderEngine)
Moonray currently relies on USD 22.11. I’ll have a go at rebuilding with USD 23.11 and let you know what happens.
building for USD 23.11 seems to compile successfully (had to update a few lines in moonray)
I’m now getting this error when trying to run blender
------------------------------ blender terminated ------------------------------ blender crashed. FATAL ERROR: [TF_DEBUG_ENVIRONMENT_SYMBOL] multiple debug symbol definitions for 'TF_SCRIPT_MODULE_LOADER'. This is usually due to software misconfiguration, such as multiple versions of the same shared library loaded simultaneously in the process. Please check your build configuration. in _Register at line 139 of /src/build_linux/deps/build/usd/src/external_usd/pxr/base/tf/debug.cpp writing crash report to [ cj-rhel:/var/tmp/st_blender.934840 ] ... done. --------------------------------------------------------------------------------
There are numerous libusd files in /usr/local/lib, deleting them allows blender to start, but then I get
Coding Error: in _Load at line 260 of /src/build_linux/deps/build/usd/src/external_usd/pxr/base/plug/plugin.cpp -- Failed to load plugin 'hdMoonray': libusd_usdImaging.so: cannot open shared object file: No such file or directory in '/home/cjhosken/org/dreamworks/openmoonray/plugin/hdMoonray.so'
This is getting into pretty tricky build issues, which I don’t have time to help much more with. But maybe someone else does if the following advice does not help.
libusd_ms.so
, instead of a multiple smaller libraries like libusd_usdImaging.so
. You may need to link against a USD build that is monolithic.-undefined dynamic_lookup
to achieve that.
