Agreed the “operator version” of some tools should just be removed, or at least the key bindings replaced to call the tool instead of the operator. Circle select is best when you can navigate around your mesh, I think.
This is not possible, among other reasons because the system decided to interact with the active tools that prevents you from leaving them unless you select another active tool. It was proposed that if you were in an active tool and you pressed “ESC”, you would return to the active tool to select, but the developers didn’t want to.
Sure that’s what active tools are. They’re not temporary ! Agree this is a hassle switching to circle select and back. A middle ground solution could be to remap the operator’s keys to match those of the tool, and allow for navigation. Is it technically possible, I can’t say…
It’s not possible because breaks modal users workflow. The users of modal tools not use the Tool Shelf so can’t back to select without map other key to select.
Seems Blender 2.81 changed the shadow code… and now has sharp (and very low-resolution and ugly) shadows as default for Eevee… while the rest of the defaults in Blender, correct me if I’m wrong, are set up for PBR where smooth shadows are preferred?
At this point I don’t see a reason to keep OpenGL Depth Picking exposed in preferences. Disabling this setting causes undefined selection which even the tooltip basically admits.
If it somehow could be used to reverse the pick order then maybe it at least has an obscure edge case, but as it is now it’s just asking for bug reports.
In the latest Blender 2.82 alpha master builds, the right-click brush settings dialog in Sculpt Mode has its appearance hotspot set at the top right of the dialog, which is not very convenient when you want to quickly adjust the brush size or strength slider.
The dialog appearance hotspot used to be at a more convenient, slider-centric position. It’d be great if that could be fixed, thanks a lot.
