Attendees
- Brecht Van Lommel (Blender)
- Sergey Sharybin (Blender)
- Weizhen Huang (Blender)
- Lukas Stockner (Blender)
- Nikita Sirgienko (Intel)
- Patrick Mours (NVIDIA)
Notes
For 4.2
- Decided to accept the performance impact on AMD/Intel Metal
- The slowdown only happens on specific hardware, which developers have no access to.
- High prio reports:
- Cycles HIP-RT Memory leak #120702
- Seems to be bug in the library
- Fixed in the open source version, which 4.3 is switching to
- For 4.2 wait for the possible NIP-RT update
- Blender crashing when using metal renderer #122022
- Michael Jones was looking into it
- OpenImageDenoise CUTLASS error after rendering image #122584
- All the crucial parts are fixed for 4.2
- Illegal address error with OptiX OSL with specific materials #122779
- Possibly a driver bug, Patrick is looking into it
- Possibility is to accept it for 4.2 initial release, and either look into work-around later, or have a fix done from the driver side.
- Release notes seems to be good
For 4.3
- White point patch
- All the current feedback has been addressed, needs the final review
- Known limitation: no feedback when picking something that is not close to blackbody radiation
- Compression of pre-compiled libraries has landed #123557
- Diffuse roughness control for principled BSDF
- Need review from the Cycles side. Weizhen and Sergey will take care of that
- EEVEE side is done
- Weizhen is looking into bug reports, solving long-standing issues
- Brecht is updating Cycles standalone
- The script cycles_commits_sync.py is in the blender.git repository
- Takes a bit longer than usually, because of the Git-LFS changes
- Brecht cleaned up the project workboard, so there is now a column for the near-term next tasks to tackle
- Alaska is working on patch to remove Intel/AMD Metal codepaths. Sergey reviews, hopefully land soon
- Volume phase functions #123532
- NVidia paper looks very interesting
- Lukas would love to have a review
- Some preliminary feedback:
- Add links to papers
- Better explanation of what the new phase functions are on artistic level
- Are the parameters good and friendly for artists?
- How do you mix different lobes?
- Replace current one with the new one?
Future:
- Split principled BSDF node
- Helps EEVEE parameters (the GLSL parameters limit)
- Helps OSL to discard unused closures
- Probably better be done on the render engine side (as opposite to the Blender side) since layering might be done differently by different engines
- How to handle volumes
- Best acceleration structure
- Combine them or sample separately
- Look into what the state of the art is
- The meeting mainly raised this topic, needs further investigation
- Multi-part EXR files #123727
- Helps speeding up load of EXR in external software
- Eventually Blender will also only load requires passes, so will help there as well
- Implement as an option, or even by default
- Nikita raised a discussion of solving technical debt
- Would be good to tackle it shorter term, and not for Blender 8.0
- Testing frameworks are available already, but some aspects of Blender/Cycles might be hard to unit test
- Need to look into it, and make code easy to unit test
- Sergey is very interested in this, but has limited time. Nikita might have time to look into it for the denoise device selection
- In the longer term we should strive towards accepting new features with tests included
- Another technical debt topic was splitting up CMakeLists.txt. Could help some on-going development
- There is old-standing patch to rework CUDA kernel build to use separable compilation #119746
- Is still something to look into, but needs development time and priority
- Doing kernel compression for AoT Intel kernels is being investigated
Practical Info
This is a weekly video chat meeting for planning and discussion of Blender rendering development. Any contributor (developer, UI/UX designer, writer, …) working on rendering in Blender is welcome to join and add proposed items to the agenda.
- Google Meet
- Google Calendar Event
- Next Meeting: July 9 2024, 5 to 6 PM Amsterdam Time (Your local time: 2024-07-09T15:00:00Z)
