Thought I had an easy fix by using view3d.dolly and changing the deltas to +/-2000. It gives the behaviour I wanted for when you are so close to your focal point that the zoom increments go way down. The problem with this is that with dolly, you are moving the camera instead of adjusting the zoom. So focal point moves outward along with your view, and pivot/orbit goes with it.
So, semi-quick fix for this is to just duplicate the view3d.zoom and plug everything in to dolly. Tried to make a new zoom mode called view3d.zoomfast, same way I made a new repeat tool & history mode, rather than replacing repeat last & history, but it kept acting like something was missing.
Don’t care for dolly anyway, and don’t see myself ever needing that particular camera functionality, so we are good to go.
Basically, copy everything from the normal zoom section of view3d_edit.c (lines1755-2280). Don’t just slam all of it into the dolly section, you’re going to have to rename a lot of things from viewzoom to viewdolly, etc. Leave the OT and modal sections alone. Remove the stuff in dolly that doesn’t exist in the zoom area, and add the missing zoom area stuff.
Finally, the part that actually does something we want, zoom in/out faster. Go find the viewdolly_exec area, if you’ve been following along, it no longer has its original content in there, but the viewzoom_exec is there instead. Change the step floats, they are inversions of each other. One for zoom in and the other for zoom out. If you don’t want the in and out to be the same, you can play around with it.
I’m going with triple speed in/out. 3.0f and 1.0f/3.0f respectively.
If you didn’t mess it up too bad, you will be able to build, and everything will be functional.
I have normal zoom mapped to mousewheel up/down, and dolly zoom (fast zoom) mapped to shift-mousewheel up/down.
