Hello there,
I m having hard time building Blender in Windows 10.
Here is the log file—> Pasteall/wqX5 (Plain Code)
Thanks for your help
Hello there,
Can’t seem to repro that locally, the bots also seem ok, try a fresh pull and if that doesn’t work a clean
Since morning I have been fighting with it, this is fresh master, I have nuked the Cmake cache file, let’s see.
Allright that’s a little more drastic than i was going for, which was
but hey, it’s worth a try
Do you mind check? it seems like you have 112 projects while I got 166 projects didn’t you by any chance turn some project off?
Cmake nuke didn’t work. I doing your approach, let’s see.
I’m on a lite build, given your issues came out of geo nodes, that’s ok. if not, the bots are on the most complete build and also have no issues currently
I got it worked out, so clean solution and rebuild solution did the work, thanks for your help
