Why is it so difficult to find shortcuts in the Preferences?
For example, I want to know the shortcut for the “interaction mode”, and It’s nowhere in Key-map. Rather than making people search up on google how to do it, it should be easy to find on the key-map. I mean the name of the thing your clicking on shows up when you hover over it so that same keyword that is used should show up in key-map.
00%20PM
Probably, tooltip is too much descriptive.
If you type object mode in filter of user preferences ; you should find relative shortcuts.
