I’m getting together a pretty long list of issues I’m coming across with 2.8. I’m sure several of these will be fixed before bugs reports are accepted . Should I make all these as separate bug reports? Post what I’ve found so far here?
After the release of the Beta version, we hope all before the end of October
When the bug tracker is open for general reports, you can make each issue a separate bug report.
OK, I’m sure most will prolly be fixed by then. Some of them are pretty obvious.
Then you better double check before you report them once the tracker opens
@brecht is bug tracker open for general reports? I see some things getting reported that’s not crashes.
