i use “Alt” for snapping the views instead of the far away numpads, so i found this cool trick in the latest build of 2.83 alpha or is it a bug? even if it’s a bug i hope it makes it as a feature
If you snap the views from top/bottom it goes to ortho projection and if it’s front/back ,right/left then it’s Perspective, this makes it much more easier to switch views.
