What if to make an opportunity to keep preseta of all panel of settings?
That is for example in the first case I would like to do a render and I need to expose 1920х1080,
samples 512, a render of “cycles” and with the switched-on smoothing modifiers.
And in the second case I need to make a render of the viewport. And so in the second case I need to render 720x540, with the switched-off modifiers of smoothing and that there were 16 samples. And I need to switch often between these modes. And besides also to change a format of a render. In the first case it is EXR, and in avi second just.
And so whether it is possible to realize the choice of global settings of filepath, render, samples and other as preset?
