as header says there is inconsistency in transformation(rotate namely) gismo placement during rotating elements in hierarchy. When I have two objects: two cubes the first one is root, then second one is slave(parented under empty which is moved up) and finaly empty is child of first cube. Then I select the first and second cube and want to rotate them both with individual origins option on. The rotate gismo is centered between these two cubes.
When I have two simple bones(create simple bone, then extrude its tail) and I go to pose mode and wanna rotate these two bones together with individual origins option on the rotate gismo stays on root’s bone position and this is in my opinion correct behaviour.
Check
attached screegrabs.Thanks.
