The “view transform” and “color space” submenus are not displayed in blender 2.82, Russian language
Greetings, comrades! I have a problem. The “view transform” and “color space” submenus are not displayed in blender 2.82, and the same problem was encountered in the last build. I couldn’t find an answer on the Russian-language response resource, and no one has encountered this. If this does not help, I will already write to the developers. I’m a beginner and I really like to learn this craft, I watch video tutorials and repeat them for the time being, but sometimes I just can’t reach the end because I don’t see the same result as in the lesson. Thanks!
What’s your operating system?
win10 x64
Maybe it’s because of the computer components?
Nope, but it may be because of some faulty preferences folder.
Do you use the zip file or the exe installer?
You can go to %appdata% then go to the blender foundation folder and delete or rename the folder with the preferences, and try starting blender again, don’t import preferences from an older version.
I used a exe file. Renamed the folder and settings, everything was reset but did not help.
@invader666 you mean this?
Yes, in this submenu. I don’t have the “view trasform” parameters displayed.
