So I tried to investigate why exactly Cycles does not work on GCN1 cards.
With the latest drivers I can get Blender to compile the kernels successfully, it does however require setting the GPU_FORCE_64BIT_PTR
environment variable to 1 - without this the amdgpu-pro
OpenCL driver does not return any memory info.
Upon loading all kernels Blender crashes with a divide-by-zero in DeviceSplitKernel::max_elements_for_max_buffer_size()
, since the call to state_buffer_size(kg, data, 1024)
returns 0.
state_buffer_size()
loads the kernel_state_buffer_size.cl
kernel onto the device and then returns the size as set by the kernel (*size = split_data_buffer_size((KernelGlobals*)kg, num_threads);
Does anyone have any ideas why it would return 0
under GCN1?
I tried changing the returned value to 2048
(*size = 2048;
) just to check - and to my surprise
size_buffer.copy_from_device(0, 1, 1);
size_t size = size_buffer[0];
which is supposed to get the size
back from the device - still returns 0;
Could this be a bug with copy_from_device/device_copy_from/OpenCLDevice::mem_copy_from
under GCN1?
I would be glad to debug this further if anyone could give ideas as to where to look at next.
