I am making an add-on, I have 4 light buttons that I want to remove the center gap going both ways so that all buttons are aligned, butting against each other
Here is image and code…
col = split.column()
col.scale_y = rowH
col.operator('viewed3d.add_pointlight', text="Point", icon="LIGHT_POINT")
col.operator('viewed3d.add_sunlight', text="Sun", icon="LIGHT_SUN")
col.scale_y = rowH
col.operator('viewed3d.add_spotlight', text="Spot", icon="LIGHT_SPOT")
col.operator('viewed3d.add_arealight', text="Area", icon="LIGHT_AREA")
testure
December 29, 2019, 11:13pm
#2
Nope… messed it up even worse
I already know about the article. I am a newbie and all that tells me is what the class/method is, but not how to use it. They really should put code examples on the docs… useless to newbies.
def draw(self, context):
layout = self.layout
self.layout.label(text="Meshes")
rowH = 1.2
split = layout.split()
col = split.column(align=True)
col.scale_y = rowH
col.operator('viewed3d.add_cube', text="Cube w/Bevel", icon="CUBE")
col.operator('viewed3d.hq_sphere', text="Hi-Res Sphere (64x64)", icon="SPHERE")
col.operator('viewed3d.add_suzanne', text="Suzanne w/SubSurf", icon="MESH_MONKEY")
self.layout.label(text="Lights")
rowH = 1.2
col.scale_y = rowH
rowH = 1.2
col.scale_y = rowH
testure
December 29, 2019, 11:56pm
#4
I’m not sure what your desired result is supposed to be, you’re using column so what you’re showing me looks correct. If you’re trying to group into rows use row instead.
Like I said earlier… trying to remove all gaps in between all 4 buttons.
Looking for this kind of look (minus Grease pencil text)…
testure
December 30, 2019, 2:04am
#6
right. use rows, and set align to True
col = layout.column(align=True)
row = col.row(align=True)
row.op()
row.op
row2 = col.row(align=True)
row2.op()
row2.op()
That worked!!!
THANK YOU SO MUCH!!!
Code that works…
row.operator('viewed3d.add_pointlight', text="Point", icon="LIGHT_POINT")
row.operator('viewed3d.add_sunlight', text="Sun", icon="LIGHT_SUN")
row2.operator('viewed3d.add_spotlight', text="Spot", icon="LIGHT_SPOT")
row2.operator('viewed3d.add_arealight', text="Area", icon="LIGHT_AREA")
