When i use cycles preview,
it shows this pictureand can’t preview smoke
How can I solve this problem
Thanks
Thanks
AFAIK devtalk is not better place for make support question, however unplug from Mateial Output any node from Surface and plug only Volume node. IMHO blender.chat/channel/support channel should be more appropriate place to your question. material example is made on right selected cube
And this seems to have nothing to do with the material, because it can be shown before, because there is a problem that caused the software to exit halfway, and then can not be normal preview, simulation smoke when the cycles can not be previewed
