I’m trying to understand some of the blender source code. Something I’ve noticed when looking at node definitions in nodes.cpp is that some nodes will pass both a stack offset for a parameter, as well as the value directly when adding a node for SVM compilation.
An example is the wave texture node
void WaveTextureNode::compile(SVMCompiler &compiler)
ShaderInput *scale_in = input(“Scale”);
ShaderInput *distortion_in = input(“Distortion”);
ShaderInput *dscale_in = input(“Detail Scale”);
ShaderInput *detail_in = input(“Detail”);
ShaderInput *vector_in = input(“Vector”);
ShaderOutput *fac_out = output(“Fac”);
ShaderOutput *color_out = output(“Color”);
int vector_offset = tex_mapping.compile_begin(compiler, vector_in);
compiler.add_node(NODE_TEX_WAVE,
compiler.encode_uchar4(type,
compiler.stack_assign_if_linked(color_out),
compiler.stack_assign_if_linked(fac_out),
compiler.stack_assign_if_linked(dscale_in)),
compiler.encode_uchar4(vector_offset,
compiler.stack_assign_if_linked(scale_in),
compiler.stack_assign_if_linked(detail_in),
compiler.stack_assign_if_linked(distortion_in)),
profile);
compiler.add_node(__float_as_int(scale),
__float_as_int(detail),
__float_as_int(distortion),
__float_as_int(detail_scale));
tex_mapping.compile_end(compiler, vector_in, vector_offset);
The values are passed directly with additional add_node calls. I’m not sure where this data ends up as it doesn’t seem to be referenced in the shader?
ccl_device void svm_node_tex_wave(
KernelGlobals *kg, ShaderData *sd, float *stack, uint4 node, int *offset)
uint4 node2 = read_node(kg, offset);
uint type;
uint co_offset, scale_offset, detail_offset, dscale_offset, distortion_offset, color_offset,
fac_offset;
svm_unpack_node_uchar4(node.y, &type, &color_offset, &fac_offset, &dscale_offset);
svm_unpack_node_uchar4(node.z, &co_offset, &scale_offset, &detail_offset, &distortion_offset);
float3 co = stack_load_float3(stack, co_offset);
float scale = stack_load_float_default(stack, scale_offset, node2.x);
float detail = stack_load_float_default(stack, detail_offset, node2.y);
float distortion = stack_load_float_default(stack, distortion_offset, node2.z);
float dscale = stack_load_float_default(stack, dscale_offset, node2.w);
float f = svm_wave(
(NodeWaveType)type, (NodeWaveProfile)node.w, co * scale, detail, distortion, dscale);
if (stack_valid(fac_offset))
stack_store_float(stack, fac_offset, f);
if (stack_valid(color_offset))
stack_store_float3(stack, color_offset, make_float3(f, f, f));
If anyone could take the time to explain, or point me towards a resource or part of the code which explains what is happening here I would really appreciate it.
