And also that :
The calculation of the normals is a bit broken.
And also that :
I did a little testing. Looks like this issue only applies to using Diffuse BSDF normals.
If you connect same bumps to Principled BSDF normal socket it behaves correctly.
From my testing this is not true. The normals are clamped at 45 degree of perturbation, on both the Diffuse BSDF and the principled BSDF.
Both these images are rendered with the principled BSDF:
Just to be clear (and by the way, this probably should be its own discussion, as it’s unrelated to Principled v2? - maybe a mod could move this stuff to its own thread?)
Is this affecting any Normal socket, or is this specific to the Displacement socket in the output node?
I suspect those two behave differently as Displacement would be expecting potentially unlimited ranges…
If it happens with a Normal socket, it likely happens with all of them. For instance, the Fresnel node might also be affected. Unless it’s somehow specific to just actual shader nodes.
Moonray went open source recently and I was reading over the documentation.
I noticed they had support for overlapping dielectrics (Like water in a glass cup). I believe there was plans for something like this with Principled v2, and I was wondering if this might be similar to the implementation planned for Cycles.
Documentation on overlapping dielectrics from Moonray: Overlapping Dielectrics
Overlapping Dielectrics would not be a Pv2 feature, but rather a general Cycles feature
Is there any new about Principled v2?
Has @lukasstockner97 back to work to this project?
This is from this/last weeks Cycles meeting
The principled-v2 branch has now been purged from the list of branches after the latest cleanup:
I hope this is not a bad sign and Blender 3.6 is still the target.
I hope so too that development is still aim for 3.6.
My guess this was probably an accident, or the wish is to shift the development into a fork instead of a branch in the main repository.
If the desire is to stop development on Principled V2, then we would probably see it in some up coming meeting notes.
If anyone was concerned that all the progress for the Principled V2 branch was lost due to it’s removal, it was not. There are multiple copies spread across various forks of Blender, and I just pushed a copy to my fork as well.
Here are a few forks that contain the Principled V2 branch:
Thanks, I didn’t expect the Principled v2 development to be binned just because the branch disappeared and I still have high hopes for 3.6.
According to the release schedule, 3.6 is just a few weeks ahead:
(the lower part is about Blender 3.6)
but “bcon2” means “improve and stabilize”
which also means “no new features”. Everything has to be ready for main branch until the 17th week. And the 17th week of this year is this week if I’m not mistaken.
Fingers crossed!
Here is the planning : Milestones - blender - Blender Projects
Continuing the discussion from 24 April 2023:
On the Blender Foundation Grant page, Lukas is listed in the part time grants for January - June 2023. Doesn’t that imply some kind of reporting ? Lukas’s weekly report page hasn’t been updated in 3 months.
I don’t mean to sound too inquisitive, I’m simply eager to see this feature land and would appreciate some clarity to manage my expectations.
True he’s been quiet lately but in the past week he worked on the PV2. He removed the multi GGX code - if I remember correctly. And he’s showed up on the new Hair shading implementation by weizhen. I feel there’s a lot of behind the scene work
I know, it’s probably too late to bring this up but there was a discussion in another place between blender heads and I was surprised that not many people in that discussion were aware about Arnold Standard Surface and the fact that it’s open sourced.
That made me thinking are the Blender devs aware of this? I think you are but then I have another question.
Is there a particular reason you didn’t think of implementing it in Cycles and instead went the hard way doing everything from scratch yourself?
Personally, as an artist, I find Arnold Standard Surface the easiest to understand and use. There is also a wide adoption of the standard. Both Redshift and Octane implemented it. I think render engine in Clarisse used it too. It’s probably implemented in other software too I’m not aware.
It also has a great compatibility with MaterialX out of the box since Autodesk contributing to MaterialX standard as well.
Adobe Substance team is also announced that they and Autodesk are working on common open source material standard. I believe it’ll expand/unify the Arnold Standard Surface and Adobe Standard Material and they’ll also keep supporting compatibility with MaterialX.
So a lot of the work was done already with Arnold Standard Surface and it’ll also keep getting support and development where needed. Doesn’t it make sense to use this work? Especially when it was proven in production for many years and also have good users feedback?
Doesn’t it seem like a bit wasteful investing devs time on a new uber shader when there is a good one available already and it’s open source?
@AlexeyAdamitsky I’m quite familiar with it, I worked on the initial implementation in Arnold and gave it its name.
Most of the work for Principled v2 is not in that small amount of open source OSL code you linked to, but rather in the implementation of the BSDFs, subsurface scattering, albedo scaling for energy conservation, sampling, upgrading the various individual BSDF nodes along with it, Eevee and SVM implementation, backwards compatibility, node UI, etc.
Some of the same improvements as the Adobe shader are being done in Principled v2 as well. I think it makes more sense for us to aim at that iteration instead of trying to match Standard Surface exactly which is somewhat outdated now.
I was aware that you worked on Arnold didn’t know about the rest. Thanks for sharing. I like the name standard surface. It has a good ring to it.
This is great to know. I always felt like Principled wasn’t doing enough to give me the expected results in Cycles while in other render engines it was very easy to get what I needed with standard surface. But it’s been discussed countless times by other users so I won’t go there.
Yes, knowing what you explained I will agree. If I understand it right your are basically working on the next iteration/version of the standard surface. It seems like Blender, Autodesk and now Adobe are all converging on one standard surface which should also be compatible with MaterialX. It would be amazing if was the case and the surface had consistent naming and behavior across the apps. It makes the life of the artist so much easier.
The last small suggestion is to name the new version of the shader - Standard Surface. It can be Cycles Standard Surface. Like Adobe Standard Surface. It’s a really smart name and is so mach easier to fast search when adding the shader (at least for the right hand users). You just have to write “std“ to get access to the shader. It’s way more difficult/annoying to reach all the way to the right on the keyboard to “p" and than all the way back to “r" and again all the way to the right to “i“ to find the most used Principled shader.
Anyway, I am really happy you’re working on the updating the shader. Thank you.
I think he’s talking about PV2 and not something completely different.
