Hi
I am a developer of a blender addon that allows to send offscreen rendered textures to other applications via spout (for windows) and spyhon (for OSX).
For this I am using the offscreen render approach (as described here) and I have it slighty adaped by passing on the rendered texture to the python API for spout rsp. spyhon.
This works flawlessly for windows, but on OSX I encounter the following issue:
The video shows how on OSX the texture is not completely send every frame, only a sliver on the left side is updated frequently. But here is the catch: In the second half of the video where I orbit around in the 3d viewport, the texture is correctly updated (albey with an unreasonable frame rate - but thats probably a different issue with the draw_handler).
So it looks as if there is a kind of texture refresh happening in the background when the viewport camera is moved around, which is not happening when I just manipulate objects. And I wonder if someone can point me in the right direction, so I can call this function via python for each frame, so a user doesn’t have to continoulsy move the viewport cam orientation.
any hints are welcome
cheers - martin
