When you shout into the abyss, nobody shouts back at you…
PROBLEM
- I have a very large shader node graph
- I must drag from one node all the way across to another node
- If I zoom out, I can’t tell which ouput I’m dragging from
- If I zoom in, I can’t see my input target
SOLUTION
- After the user has begun dragging from a node, the view should auto scroll when you get close to the edge
- Ideally, the auto scroll should go faster the closer to the edge you get
