I’m using the latest Beta build of Blender 2.8 on Mac OS from February 15th. Strangely Windows and Linux are up to date but Mac still has a build from a week ago.
I mention this because the latest Mac OS build no longer updates the render viewport when you edit a node. You have to reload the entire blend file to see your changes. For instance, if you change the base color or add a node to a material, no change will appear on your object -even in rendered view. But if you save and restart the file, your changes are applied.
Is this a bug? When’s the next build that will resolve this issue?
I understand that because it’s in Beta, only developer comments are being addressed right now but I just want to know if this issue can be fixed in the next build ASAP. Thanks
