I’m trying to build Blender for the first time on MacOS, and am encountering some errors when linking:
Consolidate compiler generated dependencies of target blender
[100%] Building C object source/creator/CMakeFiles/blender.dir/buildinfo.c.o
[100%] Linking CXX executable ../../bin/Blender.app/Contents/MacOS/Blender
Undefined symbols for architecture x86_64:
"_GCControllerDidConnectNotification", referenced from:
_IOS_JoystickInit in libSDL2.a(SDL_mfijoystick.m.o)
_IOS_JoystickQuit in libSDL2.a(SDL_mfijoystick.m.o)
"_GCControllerDidDisconnectNotification", referenced from:
"_OBJC_CLASS_$_GCController", referenced from:
objc-class-ref in libSDL2.a(SDL_mfijoystick.m.o)
"_WebPConfigInitInternal", referenced from:
OpenImageIO_v2_3::webp_pvt::WebpOutput::open(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, OpenImageIO_v2_3::ImageSpec const&, OpenImageIO_v2_3::ImageOutput::OpenMode) in libOpenImageIO.a(webpoutput.cpp.o)
"_WebPDecodeRGBAInto", referenced from:
OpenImageIO_v2_3::webp_pvt::WebpInput::read_current_subimage() in libOpenImageIO.a(webpinput.cpp.o)
"_WebPDecodeRGBInto", referenced from:
"_WebPDemuxDelete", referenced from:
OpenImageIO_v2_3::webp_pvt::WebpInput::open(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, OpenImageIO_v2_3::ImageSpec&) in libOpenImageIO.a(webpinput.cpp.o)
OpenImageIO_v2_3::webp_pvt::WebpInput::close() in libOpenImageIO.a(webpinput.cpp.o)
OpenImageIO_v2_3::webp_pvt::WebpInput::~WebpInput() in libOpenImageIO.a(webpinput.cpp.o)
"_WebPDemuxGetChunk", referenced from:
"_WebPDemuxGetFrame", referenced from:
OpenImageIO_v2_3::webp_pvt::WebpInput::seek_subimage(int, int) in libOpenImageIO.a(webpinput.cpp.o)
OpenImageIO_v2_3::webp_pvt::WebpInput::read_subimage(int, bool) in libOpenImageIO.a(webpinput.cpp.o)
"_WebPDemuxGetI", referenced from:
"_WebPDemuxInternal", referenced from:
"_WebPDemuxReleaseChunkIterator", referenced from:
"_WebPDemuxReleaseIterator", referenced from:
"_WebPEncode", referenced from:
OpenImageIO_v2_3::webp_pvt::WebpOutput::write_scanline(int, int, OpenImageIO_v2_3::TypeDesc, void const*, long long) in libOpenImageIO.a(webpoutput.cpp.o)
"_WebPGetDecoderVersion", referenced from:
OpenImageIO_v2_3::webp_imageio_library_version() in libOpenImageIO.a(webpinput.cpp.o)
"_WebPGetInfo", referenced from:
"_WebPPictureFree", referenced from:
OpenImageIO_v2_3::webp_pvt::WebpOutput::close() in libOpenImageIO.a(webpoutput.cpp.o)
"_WebPPictureImportRGB", referenced from:
"_WebPPictureImportRGBA", referenced from:
"_WebPPictureInitInternal", referenced from:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[3]: *** [bin/Blender.app/Contents/MacOS/Blender] Error 1
make[2]: *** [source/creator/CMakeFiles/blender.dir/all] Error 2
make[1]: *** [all] Error 2
make: *** [all] Error 2
What did I forget to do here?
The only thing I can think of as potentially unusual is that I ran make update
, then checked out v3.1.2
before calling make
Calling xcode-select --install
shows that XCode is already installed.
