Hi. I’ve recently built the Mantaflow branch of 2.81 on Ubuntu 18.04 and everything seems to work. The simulation and most of it’s settings work fine, but for some reason the domain object keeps getting rendered. I’ve tried turning it off in the render, but that doesn’t work. It just shows the bare emitter object and no smoke. This happens if I manually setup the domain and flow object or if I use quick smoke.
I’ve seen a posting about needing to use someone’s custom build, but that just points back to here.
