Hi
I build a py lib that contains higher level functions that target multiple versions of the same fucntionalities in 2.79 and 2.80. So I just call the corresponding higher level function instead of the Api call in my addons (like setActiveObject
in the actual addon). The corresponging call is decided by the lib based on bpy.app.version
Now this works for functions but I cant integrate it well in a script because the main issue is bl_info
. Created 2 bl_infos that are under 2 if statements basically at the top, since I need to run couple commands just before the bl_infos to make which one to register, this does not seem to work well.
So my question is this. Does the bl_info dict has to be at the top of the init.py ? if so what are the work arounds so that I stop making 2 different addon scripts. My compability lib works fine I just need to make sure this bl_info works so that the addon registers properly.
It is just that maintaining two different addons is not fun, while they are %99 of the same code lines.
thanks
