I apologize for my mess, I will clean up all the files and try to rebuild.
Thank you for your patient reply!
Now I see same issue to update master, then I try to svn cleanup and svn update,
but everytime I try this in win_64vc15 directory, it freeze after download same file.(I suppose so). I try same command (svn cleanup, svnupdate), but I have no success.
C:\myprograms\blender-git\lib\win64_vc15>svn cleanup
C:\myprograms\blender-git\lib\win64_vc15>svn update
Updating '.':
A openvdb\include\openvdb\tree
A usd\plugin\usd\usdShaders\resources\shaders\previewSurface.glslfx
A usd\plugin\usd\usdShaders\resources\shaders\transform2d.glslfx
A openvdb\include\openvdb\tools\VolumeToSpheres.h
A openvdb\include\openvdb\tools\PoissonSolver.h
A openvdb\include\openvdb\tools\SignedFloodFill.h
A openvdb\include\openvdb\tools\Interpolation.h
A openvdb\include\openvdb\io\File.h
A openvdb\include\openvdb\io\io.h
A openvdb\include\openvdb\tools\TopologyToLevelSet.h
A openvdb\include\openvdb\tools\VectorTransformer.h
A openvdb\include\openvdb\tree\LeafBuffer.h
A openvdb\include\openvdb\tree\LeafNodeBool.h
A openvdb\include\openvdb\tools\VolumeToMesh.h
A openvdb\include\openvdb\tools\Dense.h
A openvdb\include\openvdb\io\Compression.h
A openvdb\include\openvdb\io\TempFile.h
A openvdb\include\openvdb\tree\RootNode.h
A openvdb\include\openvdb\tree\NodeUnion.h
A openvdb\include\openvdb\util
A openvdb\include\openvdb\util\ExplicitInstantiation.h
A openvdb\include\openvdb\util\logging.h
A openvdb\include\openvdb\tree\InternalNode.h
A openvdb\include\openvdb\tree\LeafNode.h
A openvdb\include\openvdb\tree\NodeManager.h
A openvdb\include\openvdb\tree\ValueAccessor.h
A openvdb\include\openvdb\tree\Iterator.h
A openvdb\include\openvdb\util\PagedArray.h
A openvdb\include\openvdb\util\Formats.h
A openvdb\include\openvdb\util\Util.h
A openvdb\include\openvdb\util\NodeMasks.h
A openvdb\include\openvdb\util\Name.h
A openvdb\include\openvdb\Metadata.h
A openvdb\include\openvdb\Exceptions.h
A openvdb\include\nanovdb\util\CudaDeviceBuffer.h
A openvdb\include\nanovdb\util\GridBuilder.h
after download GridBuilder.h , windows 10 command prompt usually freeze.
There are a couple of big files in this update (USD is ~1.4GB) it’ll likely take a bit, you could check in the resource monitor (linked in the task manager on the performance tab) to see if svn.exe is transferring data or not.
OK. next time I will check svn.exe.
I retried make update again. Then console show, “python not found in lib folder”
so I follow this.
git pull finally update correctly. thanks.
