I’m trying to create a macro that does something before and after baking. It’s supposed to bake multiple times.
The issue is that after the first bake is finished, the macro pauses until I move the mouse. Then it bakes the next one.
Is there a way to keep the macro running through all baking operations?
Here’s a file which shows a simplified version of this:
The reason it stops is because there’s no input to generate a callback for the bake modal. You can get around this by adding an event timer to generate a tick. Should kick start subsequent bakes.
