Library override has been de-prioritized since its introduction and it’s being delayed at each release. Looking for a way to speed-up things.
T53500 Library Override (parent task) lists this subtask:
“Define much more RNA properties as overridable (this is easy-monkey work mostly).”
If it’s easy, is it realistic to address this item as “multiple-object edit” has been addressed by enabling several small contributions? (ref to T54643)
Of course, this would require some reference example(s) to be provided by core dev team along with a list of properties to be covered, to manage concurrent efforts, but once done, people might jump in and help.
Also allowing people to understand the basics of override might enable more complex contributions later on (especially in the area of animation where override support is really missing).
Regards
