Obviously it should be analyzed but I think it is useful for almost all tools, depending on the situation it will sometimes be more useful to choose box, lasso or circle. That is to say that it would be necessary to analyze if each tool can have its drag action or a shared way of selection should be used for all the tools.
The move tool should be the default. The lack of gizmo in the selection tools makes it look weird.
About selecting components behind the manipulator.
I think this is not a problem. There are different ways one can do that.
Neither shortcut keys are used here nor changing of tools, just left click.
I think this situation happens rarely. And if for some reason one decides that non of these methods work, changing to the select tool is always an option.
This way with one mouse button we get move/rotate/scale, select (regular and box), grab (center of gizmo) and constrain to X,Y,Z axis at the same time.
No changing of tools or using extra keys.
We just need the gizmo in the selection tools, that’s all.
We can live without the gizmo, just press G, R or S as standard and click MMB to choose which axis, actually I think is better to not have it obstructing the screen.
if you compare with maya and unity for example, where you have to choose between Q, W, E and select the axis to move its kinda worse than blender.
Once you get used ti GRS, you dont want that weird arrow thing anymore.
actually we can have everything in the transform tools, here u can see i switch between them using G,R,S, not only that i can select and tweak at the same time,and even hide/show the gizmos with a hotkey if i don’t need them the only thing missing was the box select which i mapped it to ctrl+RMB, ctrl+alt+RMB…etc it works but needs getting used to, but if we can get transform tools to have box select on LMB or using active state or something(tablet users will need that), because i don’t think gizmos work well with selection tools, this will be the perfect combination,at least this is how i see it.
You are used to do things the hard way/with very few options. I’m not a fan of keyboard centric workflows only, everything needs to be balanced. Hotkeys are meant to give quick access to commands, NOT to be the only way to access them. If it’s the only way then it’s bad design.
Blender is the only 3d app with selection tools without gizmo, this is worrying.
Was “Set 3D Cursor” hardcoded to SHIFT + RMB? I can’t get rid of it even when changing the keymap. I want it to do it pressing ALT + CTRL + RMB drag.
With the new transform gizmo you can easily move/scale along two axis but with keyboard shortcuts you have to press G and then shift+ the right axis or G, shift+mmb and you have to click the right spot on the screen to find the right axis plane which is imo much more complicated than just dragging the gizmo.
What i find kind of waste is that the box select is a separated tool? why would anyone use the select tool as you have to then switch back and forth between the tools? everyone would eventually just use B shortcut as its much faster. I hope we will be able to configure the box select to the left click like we could in 2.7x? Not sure if this is still possible but haven’t managed to do this anymore?
This works only in Global orientation, which I find very limiting.
There is a way you can get the functionality of the MMB, X, Y, Z keys (and double tapping them) with just one hotkey.
I made a proposal and I wrote a script. You can test it.
For those who like it, it can potentially free up three keys and a mouse button for something else.
And for those who don’t, it doesn’t change anything.
This is how in Maya you don’t actually need to select the axis to move.
You have the functionality of G, LMB (to confirm), MMB, X,Y,Z (and double tap each of them) in just MMB (grab) and a hotkey.
6 / 9 inputs vs 2 .
extra inputs or clean viewport, where did I see this before…
No!, it works despite the current orientation, I think you dont know enough about manipulators yet.
Now we need to add a SHIFT key to the other 9 inputs.
The current process:
- First you need to grab G
- Press MMB or Shift MMB for the reference axises to appear
- Move your mouse to choose an axis (while your objects/components jump and pop all over)
- Confirm the chosen axis by releasing MMB
- Move the object where you want
- Confirm the position with LMB
To me it’s just over complicated compared to:
- hold a key
- click drag in the direction of the axis you like to position/scale your object
- release mouse button to confirm
(now if you’re still holding the button you can continue snapping, moving/scaling on different axis using just the mouse)
The concept from my previous post is not dependent on the gizmo. It can be made to work in grab mode.
This way - “cleaner viewport”, faster snapping to axis, much less input, we all win
Happy day of the 3D by the way!(today is 3rd of December also known as the 3D artist day or 3D printing day)
OK I think we got pretty sidetracked from the main topic here.
what if you want to move in free space?
I mean like in most of the time.
the problem there is one operator missing which is “Active” key.
if you use maya you know the ( x,c,v) for snapping, if you press and holding the “x” it will active the moment you release it will deactivate. this operator in blender is missing. only limit for (shift,ctrl,alt and “S” for color picker in texture paint).
I already talk about this :
Keyboard "Release" not working the correct way
hope they can add this operator its important for many cases.
Actually it is supported for many operators, the change to grab is an example of that.
hello
do not forget that in a lot of software ther’s this “left right” direction that have an imact on the selection
its really really handy and everywhere
I think you misunderstand me what I mean .
there is (click,press,release etc…) operates but one missing is the active .
which mean if you press and holding the key it will active the moment you release it will deactivate.
here example if you press and holding the “D” it will active the edit pivot, the moment you release the key it will Deactivate. this operator as I mention in the topic is missing.
Hello Mr. Brecht Sir,
Would it be possible to just make it so two (or more) tools active at the same time…?
Like for example: I would really like the select and transform tool to be available at the same time.
Then I would go and left-click select “Select Box” and e.g. shift+left-click select “Move” in the left side tool bar and I would be ready to go.
Similar to the “Vertex/Edge/Face” select in Edit Mode where you can activate all 3 components at the same time in 2.79.
This would open up the possibility of any combination anyone’s heart may desire.
Strike infinite birds with one stone! So to say
The 3ds Max selection tool doesn’t have a gizmo, unless you’re calling the object axes a gizmo. I feel like the statement should be reversed to “Blender is the only 3d app with gizmos without selection tools” since you can’t box select without a shortcut when the move tool is active; or most tools really.
