Another day, another round of functionalities that should be ported from the 3D View to the Outliner. There are instances where with a large number of objects to join it’s easier to select them via the Outliner, and it would be extremely handy to have both the context menu entry and the Ctrl+J shortcut to work there.
try this addon, it simply adds join and separate operators to outliner.
Outliner_Join_Separate.py
# ##### BEGIN GPL LICENSE BLOCK #####
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software Foundation,
# Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
# ##### END GPL LICENSE BLOCK #####
# Add-on info
bl_info = {
"name": "Join/Separate Objects",
"author": "APEC",
"version": (0, 1, 0),
"blender": (2, 93, 0),
"location": "Outliner - Mesh Objects",
"description": "Adds menu entries for Mesh Objects selected to Join/Separate",
"doc_url": "",
"tracker_url": "",
"category": "Outliner"
import bpy
from bpy.types import Operator
class OUTLINER_OT_join(Operator):
bl_idname = "outliner.join"
bl_label = "Objects Join"
bl_description = "Join Objects"
bl_options = {'REGISTER', 'UNDO'}
def execute(self, context):
bpy.ops.object.join()
return {'FINISHED'}
class OUTLINER_OT_separate(Operator):
bl_idname = "outliner.separate"
bl_label = "Objects Separate"
bl_description = "Separate Objects by Loose parts"
bpy.ops.mesh.separate(type='LOOSE')
return {'FINISHED'}
##################################### UI ############################################
def menu_outliner_join_separate(self, context):
ob = bpy.context.object
if ob is not None and ob.type == 'MESH':
layout = self.layout
layout.separator()
layout.operator(OUTLINER_OT_join.bl_idname)
layout.operator(OUTLINER_OT_separate.bl_idname)
##################################### Register ############################################
def register():
bpy.utils.register_class(OUTLINER_OT_join)
bpy.utils.register_class(OUTLINER_OT_separate)
bpy.types.OUTLINER_MT_object.append(menu_outliner_join_separate)
def unregister():
bpy.utils.unregister_class(OUTLINER_OT_join)
bpy.utils.unregister_class(OUTLINER_OT_separate)
bpy.types.OUTLINER_MT_object.remove(menu_outliner_join_separate)
if __name__ == "__main__":
register()
or add a keymap for outliner
OMG man thanks, I’ve seen you before, you’re giving out Outliner addons around the community ahahahah. Thanks a lot, but it’s a shame that these simple functionalities are not in master. Being able to select multiple hierarchies, duplicate them etc. it’s something that should really be tackled here.
