I am trying to import a UsdPreviewSurface material from a .usda-file into blender.
The problem that I am facing at the moment is that this apparently only works if the material is attached to an actual mesh. If I add the following code to the usda-file the material gets properly imported alongside with the empty dummy object:
def Mesh "ambientCG_PLACEHOLDER_DELETE_ME"
int[] faceVertexCounts = []
int[] faceVertexIndices = []
rel material:binding = </ambientCG_TactilePaving006_2K_JPG>
point3f[] points = []
texCoord2f[] primvars:st = []
If this dummy mesh is not in the usda-file then nothing happens upon import.
Is there really no way to just add a material to the list of all materials in the .blend file without pointless dummy objects? Because if that’s the case then it’s a missed opportunity. For example, when importing into Unreal Engine it is totally possible to get just a material from a file without any geometry and I love USD specifically because it allows for this use-case.
I have uploaded a small sample to Google Drive for anyone to play around with this.
