Hey
I’m sending a loop of jobs to render and I use this command as my drive >
bpy.ops.render.render(ctx, "INVOKE_DEFAULT", animation=False, write_still=True)
However as I do print before and after the command, I can see both prints happen instantly, and render does not block the execution of loop. What command can I use to “wait for render end/cancel” so that I can properly execute the loop?
Right now if I send 10 renders, only 1 will render, as the remaining 9 will run while the 1st one renders… Also any scene changes are also incorrect… sigh. Ideas?
TIA
