How to set visibility on view layers via python?
#1
What was obj.hide in Blender 2.79 is now obj.hide_viewport in 2.80.
This is different from the visibility on view layers, which describes visibility on different viewlayers, and is what the default show/hide ops manipulate and what the eye icons in the outliner represent.
Using obj.visible_get() you can return the the visibility state on the active view layer.
There is no visible_set() method however, as far as I can tell. So how can you set the visibility on the active or other view layers?
An object hidden via the hide_viewport prop, can not be unhidden by the user using ALT + H for example.
#2
