I’m not sure if I understand what you mean. My local cloned repository is old, maybe it started two years ago. Being in Master and after doing “make update” these are my outputs:
$ git checkout ‘master@{2021-06-23 14:06:00}’
warning: Log for ‘master’ only goes back to Fri, 25 Jun 2021 08:47:08 -0300.
Nota: cambiando a ‘master@{2021-06-23 14:06:00}’.
Te encuentras en estado ‘detached HEAD’. Puedes revisar por aquí, hacer
cambios experimentales y hacer commits, y puedes descartar cualquier
commit que hayas hecho en este estado sin impactar a tu rama realizando
otro checkout.
Si quieres crear una nueva rama para mantener los commits que has creado,
puedes hacerlo (ahora o después) usando -c con el comando checkout. Ejemplo:
git switch -c
O deshacer la operación con:
git switch -
Desactiva este aviso poniendo la variable de config advice.detachedHead en false
HEAD está ahora en 2851602052c Add a reason for why an Addon can not be loaded. This change gives a more detailed explanation of the issue and may help the Addon Developer to identify what exactly needs to be changed.
*Sorry, part of the output is in Spanish
$ patch -p1 < patch
patching file intern/cycles/blender/blender_python.cpp
Reversed (or previously applied) patch detected! Assume -R? [n]
*“patch” is the name with which I save the file.
I really don’t know what to answer here. If I write “y” I get:
Hunk #1 succeeded at 707 (offset 2 lines).
Hunk #2 FAILED at 747.
Hunk #3 FAILED at 778.
Hunk #4 succeeded at 801 (offset 7 lines).
2 out of 4 hunks FAILED -- saving rejects to file intern/cycles/blender/blender_python.cpp.rej
patching file intern/cycles/blender/blender_sync.h
Hunk #1 succeeded at 114 with fuzz 2 (offset 12 lines).
patching file intern/cycles/blender/blender_sync.cpp
Hunk #1 FAILED at 614.
1 out of 1 hunk FAILED -- saving rejects to file intern/cycles/blender/blender_sync.cpp.rej
can't find file to patch at input line 83
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git a/intern/cycles/device/device_denoise.h b/intern/cycles/device/device_denoise.h
|--- a/intern/cycles/device/device_denoise.h
|+++ b/intern/cycles/device/device_denoise.h
File to patch:
That is basically what I do manually when I do “git checkout [base]” when description gives “base” information, obviously when I apply the patch with “patch -p1 < patch” it just successfully patch all files in that case.
