Please help me. How to add normals section in custom panel?
Hello, I have a similar issue. Is it possible to access Viewport Overlays via Python? It seems that the data path to the overlay, where these settings seem to be located, is not available via e.g. bpy.data.screens[âScriptingâ].overlay. Could overlay be made available via bpy?
The âScriptingâ screen doesnât have an overlay attribute. To get this data, the best thing to do is use the correct context. A lot of the python tooltips you see in blender are context-sensitive, you canât just drop them into the console and have them work. To get the overlay attribute (and all of the properties therein), you need to first get a reference to the correct screen object. The easiest way to do this outside of any âknownâ context would be thus:
import bpy
from pprint import pprint as pp
for a in bpy.context.workspace.screens[0].areas:
if a.type == 'VIEW_3D':
pp(dir(a.spaces[0].overlay))
If you are already in the correct context (ie: you are running an operator that is guaranteed to be run from a VIEW_3D area), you can simply use context.area.spaces[0].overlay
directly.
And to answer the OPâs original question that went unnoticed for 8 months until you bumped this thread, the code for most of the viewport hudâs UI is in space_view3d.py, relevant excerpt provided below for posterity:
class VIEW3D_PT_overlay_edit_mesh_normals(Panel):
bl_space_type = 'VIEW_3D'
bl_region_type = 'HEADER'
bl_parent_id = 'VIEW3D_PT_overlay_edit_mesh'
bl_label = "Normals"
@classmethod
def poll(cls, context):
return context.mode == 'EDIT_MESH'
def draw(self, context):
layout = self.layout
view = context.space_data
overlay = view.overlay
display_all = overlay.show_overlays
col = layout.column()
col.active = display_all
row = col.row(align=True)
row.prop(overlay, "show_vertex_normals", text="", icon='NORMALS_VERTEX')
row.prop(overlay, "show_split_normals", text="", icon='NORMALS_VERTEX_FACE')
row.prop(overlay, "show_face_normals", text="", icon='NORMALS_FACE')
sub = row.row(align=True)
sub.active = overlay.show_vertex_normals or overlay.show_face_normals or overlay.show_split_normals
sub.prop(overlay, "normals_length", text="Size")
Thanks, this clarifies the usage of overlays a lot! Good to know that Python tool tip data paths may need to be modified.
