I happend to need to make script which can re-target mesh shape keys driver.
I could find some infomation but I still not see stable clear work-flow so hope if someone can help me,
I have mesh object with some shape keys. then shape keys values are driven by armatureA object properties and bone rotation.
When I append the mesh object to another blend scene armature, and attach mesh for the armatureB with armature modifier,. it can pose without problem, (2 armature have same bones) but those shape keys driver not work any-more because rig ID change.
all shape keys still keep driver (but target rig changed), then I only need to change DriverTarget ID from Armature A to Armature B.
then how I can change the DriverTarget from “ArmatureA” to “ArmatureB”
for
bpy.context.active_object.data.shape_keys.key_blocks[“key1”] ?
I know to access driver,
I need to use mesh.shape_keys.animation_data
But how I can access driver of specific shape-key with the labell name like “key1” “key2” etc?
